Old 10-30-2007, 10:53 AM   #1 (permalink)
gragravar's Avatar
Default lets play guess the source of the coolant leak
alright, while driving home from playing hockey Sunday night I got a flashing light on the dash indicating that the coolant level was low. luckily the temp guage hadnt gone above normal, so I added a little water and took it easy on the remainder of the drive home. In the daylight yesterday the coolant resevoir was almost empty and there seems to be some coolant puddled on top of the engine in the V between the valve covers.
I topped up the coolant tank, and nothing leaked out onto the ground overnight. I'll take it out for a drive when I get home this afternoon to see if things start leaking again, but in the mean time, any guesses as to the best place to start searching for a leak?
FWIW, I did have my water pump replaced about 500 miles ago.
current rides:
2004 Land Rover Discovery II SE7 (still stock)
1992 Range Rover Classic (work in Progress)
2003 Audi allroad (more than a little modified)
1999 BMW R1100S
2001 BMW 330i (wife needed something to drive)
gragravar is offline   Reply With Quote
Old 10-30-2007, 11:13 AM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
heads??? Are you getting any white smoke/steam out the rear?
Old 10-30-2007, 11:24 AM   #3 (permalink)
Series Moderator
onslow's Avatar
there are 2 pipes that run under the inlet manifold from the rear of the water pump to the heater check cips are tight and that they havent split
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
Old 10-30-2007, 02:13 PM   #4 (permalink)
gragravar's Avatar
I hope not. It was nighttime when this started, hadnt seen any smoke previously, but couldnt see that night. I will look again. I doubt coolant would end up on top of the motor if the heads were bad.
I'll take a look there. thanks.
current rides:
1999 BMW R1100S
Old 10-30-2007, 04:15 PM   #5 (permalink)
gragravar's Avatar
woohoo, found it - not a head problem (this time)
it was a broken heater hose. this one:
dealer has one locally, so off to there to pick up a replacement.
current rides:
1999 BMW R1100S
Old 10-30-2007, 06:54 PM   #6 (permalink)
Rocky Mountain High
Funrover's Avatar
That's good news!!!! A cheap fix also!
Old 10-31-2007, 06:32 AM   #7 (permalink)
OkieRover's Avatar
Gallery: 2
I did that one and have a write up about it on my site.
I punch my clown daily.
Old 10-31-2007, 07:31 AM   #8 (permalink)
gragravar's Avatar
thats a great wirte up, even if it is a little depressing to hear how hard that hose is going to be to get to.
I had planned to do this at lunch today, sounds like I may need to alot more time than that.
wish me luck.
current rides:
1999 BMW R1100S
