Links
Old 05-07-2008, 04:15 PM   #1 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
Default Let's talk ignition upgrades...
Okay, I've searched around here and there and I found several options...here they are in no particular order:
1. Relocate ignition amplifier to near coil...either with a kit ($$) or DIY.
2. MSD 6A box. ($250~)
3. Toddco ignition upgrade ($100~)
4. HEI igntion amplifier swap (??)
5. Full HEI Buick dizzy swap. (??)
So what's the best bang for the buck?
What's everyones experience?...and give me quick run down on how you accomplished it.
Thanks,
BD
Solution or Problem...Which are you?
1994 RRC LWB, 82k miles, 4.2, Cornish Cream/Lightstone Interior, spring converted.
BullDogSix is offline   Reply With Quote
Old 05-08-2008, 06:19 AM   #2 (permalink)
Elemental's Avatar
MSD 6a is the trick way to go.
Reliable, easily gotten anywhere.... Best setup I've seen.
In fact, this guy COULD be considered a genius.
MSD Ignition instal on a Range Rover
Ignition wires go where? boarders123 Range Rover Classic 0 02-16-2007 03:58 PM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Ignition coil upgrades me.guevara Discovery Series I 68 03-04-2006 01:33 PM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
