Lifter/Rocker Arm adjust? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 11 (permalink) Old 09-20-2010, 12:07 PM Thread Starter
DiscoBenny's Avatar
Quoted: 6 Post(s)
Garage
Just out of curiosity, is it possible to adjust the rocker arms on the rocker arm panel? the only thing I remember when I put everything back together were the 4 bolts that held the rail to the head
I have a lifter tap on cylinders 1 and 3 after the engine is warmed up after 15 miles of driving and its driving me crazy.
Also, is it possible to replace lifters without taking out the heads?
1999 Disco II
2000 Disco II (RIP Baby)
1990 Range Rover Classic (stored)
DiscoBenny is offline
post #2 of 11 (permalink) Old 09-20-2010, 01:45 PM
Quoted: 11 Post(s)
Not adjustable. IF you need lifters, you need a cam.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
post #3 of 11 (permalink) Old 09-20-2010, 01:47 PM Thread Starter
DiscoBenny's Avatar
Quoted: 6 Post(s)
Garage
and the christmas presents keep coming...
1999 Disco II
post #4 of 11 (permalink) Old 09-20-2010, 07:00 PM
LANDY96's Avatar
Quoted: 0 Post(s)
Well i had a tap for a few months and thought it was the rocker arm. When i opened it up it turned out to be a bad lifter. I just bought all new lifters, i didn't see a need for a new cam. While I was there I did install the 4.6 ford injectors. Made one Hell of a difference. Between new lifters and injectors it woke that engine up! She runs so smooth and quiet I can hear the injectors poping! At a stop light i have to look down to see if she is still running its so smooth. I Did the work at 95k. I now have almost 115k.
Eric The Red
93 Range Rover Classic
-3"Rovertym progressive lift
-Rovertym 4-link
-Rovertym Trailing arms
-Rovertym extended brakelines
-Rovertym Sliders
-Rovertym Rear Bumper
-24 spline axle swap
-terrafima +2 shocks
-8000k HID light conversion
-lt-230 transfer case
LANDY96 is offline
post #5 of 11 (permalink) Old 09-27-2010, 06:38 PM Thread Starter
DiscoBenny's Avatar
Quoted: 6 Post(s)
Garage
haha nice! I just removed the Intake and checked my lifters
Every lifter on the left bank (noisy side) came out nice and easy, except the exhaust and intake lifters on cylinder one (main noise epicenter)
...I have 3 lifter with little marks and the I think now the main culprit was the cylinder one baddy as it has impact marks
I checked the cam and the lobe was not worn down and it looked normal...I just feel like an idiot for not checking the lifters when I did the head gaskets but hey...at least I know more about my vehicle right!
I'm getting some lifters after I measure the cam...hope that does the trick
1999 Disco II
post #6 of 11 (permalink) Old 09-27-2010, 07:48 PM
Quoted: 0 Post(s)
Can you give 6 bullet point description of lifter change? I'm trying to get an idea of what it takes. Thanks.
TonyX is offline
post #7 of 11 (permalink) Old 09-27-2010, 08:41 PM
albani's Avatar
Quoted: 0 Post(s)
Clean your engine! Nothing worse than getting crap and debris inside the engine
Drain coolant
Remove upper intake plenum
undo the coolant hoses to the heater, move em outta the way
mark all electrical connectors
Relieve fuel pressure and disconnect the fuel lines, move out of way
Remove lower plenum, it'll have two curved pieces of metal at the valley, dont forget the single bolt on those guys.
Remove the valve covers
Remove rocker assemblies
Remove lifters and finally the pushrods.
intake bolts I think are 13mm.
Grind down a 5/32nd 12 point and you can use em on the valve covers.
The big intake gasket can get a little sticky so it might take a little force to pull the lower intake manifold out.
Dont forget to mark everything and keep it CLEAN!
albani is offline
post #8 of 11 (permalink) Old 09-28-2010, 04:46 AM
Quoted: 0 Post(s)
Thanks, Albani. You are star.
TonyX is offline
post #9 of 11 (permalink) Old 09-28-2010, 06:12 AM
Quoted: 11 Post(s)
Replacing lifters and not the cam is false economy.
It won't be long until those new lifters will wear your cam to nubbins.
260-804-0458
PTSchram is offline
post #10 of 11 (permalink) Old 09-28-2010, 07:31 AM Thread Starter
DiscoBenny's Avatar
Quoted: 6 Post(s)
Garage
False economy, I will have to add that to my goodie bag haha
But yes the cam needs to be at least measured/changed if you do lifters...
I have only heard horror stories and judging how the previous owner treated MY Rover I wouldn't put it past anyone else to have taken a shortcut with yours (general public)
1999 Disco II
post #11 of 11 (permalink) Old 09-28-2010, 07:46 AM Thread Starter
DiscoBenny's Avatar
Quoted: 6 Post(s)
Garage
here is a bad lifter
IMGP0291 | Flickr - Photo Sharing!
1999 Disco II
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
How do I adjust the parking brake? tito5590805 Discovery Series II 6 03-02-2016 06:51 AM
How to adjust steering stops? SeattleRRC Range Rover Classic 5 07-07-2010 09:17 AM
headlight adjust repochyk Discovery Series II 5 11-25-2009 07:25 AM
Dealer Quote "bad rocker arm isn't that bad." (?) Dantley Discovery Series II 1 04-03-2008 04:45 AM
'04 Disco Passenger Seat Power Adjust??? ECL Discovery Series II 6 03-08-2007 11:59 AM
You may post new threads
You may post replies
