Old 03-07-2008, 07:37 AM   #31 (permalink)
XtremeMarine's Avatar
Your southern education is showing again! The word "easy" is nowhere in that post. I said basic. b-a-s-i-c. Read that as slowly as you need to, I know it has a whole two syllables. I might be the novice, but most of my wheeling is done with jeeps, so I learned really early the basics. And because I was a mechanic for a while, I'm the first guy to volunteer to get under everyone else's trucks to help get them back to the trailers. It's called having mutual respect for the people you wheel with. Too bad you haven't even learned that basic rule yet.
Old 03-08-2008, 02:05 AM   #32 (permalink)
Bwana's Avatar
There you go again. Try and knock someone else down because you're such a lowlife. Sorry, but I really don't have the time to discuss what an ignorant ass you are. There's just so many hours in a day. But I can be persuaded.
Bwana is offline   Reply With Quote
Old 03-08-2008, 03:22 AM   #33 (permalink)
GreatDivide1's Avatar
request to delete post......this what i didnt want to happent gents......
91 G.D.E. project/daily winter driver
93 BMW 325i project/daily summer driver:SOLD:
00 BUELL cyclone custom
http://www.snhlr.org/
GreatDivide1 is offline   Reply With Quote
Old 03-08-2008, 04:30 AM   #34 (permalink)
Ian Matthews
p76rangie's Avatar
What did you expect with suggesting that you weld up a diff in a Rangie. There is a lot more weight and usually bigger tyres which makes the tyres losing traction a lot harder. If the tyres are not going to break traction, then something else has to break.
I also find it strange that people are talking about locking hubs. This is not a Jeep forum.
If you break an axle in anything prior to a D2, you disconnect the prop shaft and pull the axles in the end that is broken or remove the drive flanges. You don't want the diff turning while you drive it home as the broken bits can stuff the diff. If you break a CV, you must remove it before attempting to drive it home.
Old 03-08-2008, 07:29 AM   #35 (permalink)
hermanpj's Avatar
Gallery: 4
this is what i find most entertaining about our discussions. sooner or later blood gets in the water and the frenzy begins.
Pat Herman
Old 03-08-2008, 12:37 PM   #36 (permalink)
KevinNY's Avatar
The point being lost here is that you are comparing your short wheelbase part time 4 wd like a sammy to a LWB full time 4 wheel drive. a Detroit is much more "invisible" in the back of a rangie or disco. I ran a detroit in the back of my Series coiler for a while and found it was not troublesome. Key is stay on or off the throttle in turns, don't release it half way through or the locker releases and you get the rear end jump you describe. I now run dual ARBs.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is offline   Reply With Quote
Old 03-08-2008, 07:58 PM   #37 (permalink)
gordo's Avatar
Something funny just happened. My brother in law just decided to Lincoln Lock his Rangie. Its a toy and he wants to give it a go. I told him what I thought but he is going to do it anyway. Mud's pretty forgiving but I got a feeling it wont last long with TSL 33X13.5s! To each his own, I hate breaking on the trail because I cut corners. Just my 2 cents and Kevin I cant wait to join you in the hybrid "club", getting closer. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
Central locking system bad? superpowerdave Discovery Series II 2 10-29-2005 09:14 AM
Central Locking on Classic andreH Range Rover Classic 7 06-29-2005 12:34 PM
tailgate central locking simon285 Range Rover Classic 1 10-20-2004 09:55 PM
