#16 (permalink) |
Ian Matthews
All the manuals state the same thing. Jack up the front wheels so both are off the ground. Make sure that the wheels are pointing straight ahead (this is because of the normal slack that will occur off centre). Loosen the lock nut and adjust the centre screw until there is less than 1/3 inch play at the steering wheel without the output shaft of the steering box moving. This is assuming that you have another person to help you. Personally I just get underneath it and move the input shaft by hand while holding the output shaft. I adjust it until there is minimal slop between the two. Recheck once you retighten the lock nut as it will move the screw up a little when you tighten it.
Once you are happy, move the steering from lock to lock and make sure there are no stiff points. But again, only worry about slop and left or right lock if they are significantly different to each other. If you have say 2 inch slop on one lock and none at the other, you are up for a reco box. Also, if you are getting a stiffness at the same place in the rotation of the wheel, it is most likely the uni's on the shaft between the steering column and the box, rather than the box itself. I hope this is of help. |
#17 (permalink) |
Ian Matthews
I forgot to answer OnSlow's question about how you can get slop at one lock and not the other. The worm shaft has bearing at each end. If the bearings at one end collapse it means that there will be more slop at the collapsed end. If you adjust the straight ahead position to having no slop, when you get to the end of the worm with good bearings, the steering will be very tight. Basically the worm sits at an angle if bearings at one end have gone.
#18 (permalink) | |
Series Moderator
perhaps we are reading from a different hymn sheet,my definition of play is unwanted movement or wear in components ie unwanted movement in a component or series of components
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
#19 (permalink) | |
Series Moderator
also worm bearing failure would cause the input shaft seal to fail causing fluid loss leading to pump and box failure. PS I will not be posting anymore info on this thread as I feel it pointless if anyone does require more info feel free to pm me anytime Thanks Onslow
#20 (permalink) | |
Ian Matthews
Onslow, what I have informed people is how you can identify a bearing failure so they don't drive with it.
But I now know not to disagree with you because when you are proved wrong after making stupid comments you close the thread so you don't have to reply. Last edited by p76rangie : 03-15-2007 at 12:29 AM. |
