Old 03-18-2008, 05:53 PM   #1 (permalink)
Default Motor has coolant in oil
Getting ready to get the RRC back on the road. The motor I purchased has (or so I was told by Specialized British) 160 plus compression all the way around. I pulled the oil pan to clean out any sludge and a small amount of coolant was in the oil and the oil that was left was a bit milky and VERY sludgy. I'm guessing I can just do the head gaskets, would you all agree? What else should I do with out getting too deep into the motor while I have it out. BTW, the rear main bearing and crank both looked good and smooth under a loop.
Thanks!
Bill
93 LWB Westminster 155+k miles
ArmyRover- "it's actually more of self inflicted torture chamber with doors and tires"- with this, I can relate!
O Crap! decals - $3.00 to your door.
Sign Guy is offline   Reply With Quote
Old 03-19-2008, 10:44 AM   #2 (permalink)
Geoffrey F Miller's Avatar
I do hope it's just the head gaskets, which it may well be. They're famous for causing trouble.
However, let's hope it's not this:-
Geoffrey Miller's website
Best of luck
Geoffrey
1985 4-door Range Rover Classic
Geoffrey F Miller is offline   Reply With Quote
Old 03-24-2008, 03:07 PM   #3 (permalink)
While you'r there, have it all apart, take a look at the liners, the do tend to slip down. My ex-'94 did that, had to have the block re-lined at a cost of $1,000.
Zubi is offline   Reply With Quote
Old 03-24-2008, 03:13 PM   #4 (permalink)
Liners look good. I am going to put in new cam, lifters, timing chain and gears while I have it apart.
Bill
95 SWB smells like coolant and blows air bubbles kkrover Range Rover Classic 33 02-15-2008 08:34 AM
Cylinder#6 Misfire & Coolant Leak tskim2024 Discovery Series II 3 02-09-2008 10:07 AM
Strange coolant leak..!! DiscoDoggII Discovery Series II 9 10-29-2007 04:46 PM
Small Coolant leak...Blow Head Gasket? maverick544 Discovery Series II 9 09-22-2007 09:27 AM
Yet Another Coolant Leak drprofessional Range Rover Classic 4 03-29-2007 02:46 PM
