Old 01-12-2007, 07:01 PM   #1 (permalink)
Default My 91 Hunter (Big pics)
Hey folks, Well I neck deep in it now.
Here's what needs to be fixed:
power mirrors no worky
rear drivers window NW
speakers shot
aftermarket head unit wired to +bat
Hatch needs work stuck?
All 4 rotors need replaced
interior wood needs work
window switch panel needs work
gear inticator need replace
headliner saggy
hood prop jiggy holder needs put back on
pass side exterior front door handle broke
driver side rear bumper corner needs fixin'
Badly faded paint
Observations/concerns
yellow engine lite on.
no tach
when first started steering seem funky like air in line.
Sometimes cold air blows from heater?
Must have been sitting for a while.
Advice I need from you folks:
rotors Front replace how to??? hubs spindle??
ext door handle how to??
Those are 205/80/16's on there 29" no lift on there right??
http://temp.corvetteforum.net/c3/norville//100_1131.jpg
http://temp.corvetteforum.net/c3/norville//100_1130.jpg
norville is offline   Reply With Quote
Old 01-12-2007, 10:21 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
The tach could be a connection at the alternator!! Rotors are easy..... It doesn't look to be lifted to me!!!! I like the color.....
Old 01-13-2007, 01:55 AM   #3 (permalink)
If you need any parts, I can probably help you. Good luck with your new toy.
Cheers,
Paul
paulgrant@mac.com
Old 01-13-2007, 02:05 AM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
Forgot to say...CONGRATS!!! Welcome to the Hunter Club!!!!
Old 01-13-2007, 05:00 AM   #5 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Congrats on your purchase!
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 01-13-2007, 05:05 AM   #6 (permalink)
Thanks guys'
I checked the connections at the alt but, I will do a better job and clean the connections today.
The rust I found so far were two holes in the rear tailgate hinge area and lots of seams. I'll hose them down with rust nuetralizer and rustolium. The body has a few rashes but no rust.
I'm a sucker for a used vehicle. I will have less fear offroad with a non-perfect body.
The reason I ask about a lift is the front lower spring mounts look raised. Like a piece of square tubing on a plate? I've seen this design on one of the sights as a lift. I'm not familular enough yet.
For tires I think I'll look for a set of rubicon take offs. I watch an old episode of 4x4tv and the ruby has 245/??/16's = 30x10x16
Old 01-13-2007, 09:56 AM   #7 (permalink)
Where is my Black Son?
Nice RR.Go get it dirty!
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 01-13-2007, 10:22 AM   #8 (permalink)
I drink too much
nfrey2's Avatar
A seconded welcome from the Hunter Club!
Nic
91 RRC Hunter Edition "The Warthog"
Made a bunch of stuff fer it.
USF Racing
nfrey2 is offline   Reply With Quote
Old 01-13-2007, 11:47 AM   #9 (permalink)
Default Brakes
I was looking at buying the Brake rebuild kit at Rovers North and I think it was going to be like $150 for both the front and rear and a local shop was going to charge me $200 something to put them on. My rotors and pads are rusted and pitted also.
Congrats and good luck and just make a list and do a little at a time. I always shop around and check ebay. We have got a few really nice parts on ebay over the last year at very good prices.
boxer is offline   Reply With Quote
Old 01-13-2007, 12:37 PM   #10 (permalink)
daway's Avatar
nice rrc! welcome to your new addiction. w/ the heat/ac. heat only blows out of the defrost vents (round) on the top of the dash near the front windsheld and the floor. ac only blows out of the center vents. alot of the item that u listed that dont work r easy fixs (knock on wood) just take your time. main thing is to check all your fluids, filters and etc. u can find owners manuals on ebay time to time and LR just put out a new cd manual for rrcs that has part number, work shop/owners manual all in one. http://www.roverparts.com/Parts/LHP29.cfm
i have the old paper work shop manual but i want to get this new cd manual. good luck
2001 X5 3.0i "dodi"
1993 RRC, county LWB "bertha"
myroverworld
Old 01-13-2007, 04:49 PM   #11 (permalink)
Thanks all for the warm welcome.
Well, the brakes are almost done. The rears no problem Fronts were an issue When I bout it the owner through in front calipers. Boy, am I glad he did. Both fronts were frozen. So the pads and rotors are comple but I need to bleed the front lines.
I also fixed the front seat the weld on the front of the seat base broke I wired it up so I can adjust the seat. I'll have to look into a new one or fix the one I have.
Thanks, yeh a little at a time. I need to get it inspected That was the hurry on the brakes.
Wheels were a PITA Stuck on there good.
bob
Old 01-16-2007, 07:32 AM   #12 (permalink)
Nomar's Avatar
Your Hunter is Eastnor green and all the green Hunters I've seen look faded. It's fine like it is, I wouldn't even bother trying to wax/restore it just let it get the flat appearance.
You can read the CEL codes under the passenger seat.
Also, if both mirrors are not working it must be your switch...
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done."
Nomar is offline   Reply With Quote
Old 01-16-2007, 08:36 AM   #13 (permalink)
Thanks for the tip on the paint, but I have one non-faded panel. Probably replaced at one time. I was hoping to get them all matched up. What kind of paint is it? clear coat? Rubbing compound and wax fix it??
I just found the link to the codes but I didn't find the code area yet. Under pass seat. Mirrors arent an issue yet.
I would like to know if I need to replace the entire exterior front door handle or could I get a rear one and just replace the silver potmetal broken part. The fronts are running $50+ and then I need to figure out the key issue. Rear handles are cheaper. PO said he would send me a spare used one?? no idea if it will show up??
I have a switch that I have no Idea what it goes to --- aftermarket toggle and it's above the dome light.
Speaking of dome lite both bulbs are gone and the switch sticks in when pushed.. hmm
bob
Old 01-16-2007, 09:33 AM   #14 (permalink)
Rocky Mountain High
Funrover's Avatar
bob
As far as paint goes.. it can shine up...But it took me about 10 hours +......... Not worth it, the fade was back in a short time!!!! Door handle, from everything I have seen you have to buy the entire thing....... The sicky switch...... Hmmm.... Put bulbs in..see what happens! do you have a pic of the from spring mod?
Old 01-16-2007, 11:01 AM   #15 (permalink)
Good to know it'll shine but it will have to wait till spring anyway. I was hoping I wouldn't have to replace the whole door handle. I'll pull it apart and look.
"do you have a pic of the from spring mod?" I'm not sure what this means? from=front? no but I will it looks like the perch shown in rovers north for no spring lift. The I though maybe that's normal cause I don't have air bags.
My goal is to run approx 31x10.5's muddies that will take me about anywhere I need to go. Bigger is alway's better but experience tells me not to, one mod to fix the last. I love the look of 33's and 4"
thanks,
bob
