#16 (permalink) | |
Rocky Mountain High
![]() Join Date: Sep 2005
it's not exact 45 angle but 45 does work!!!!! To make a cut I used a 2.75" hole saw!!!!! |
#18 (permalink) |
I'd Rather Push a Landrover than Drive a Jeep
Location: Durban, South Africa, 'til 2009. Then Back to Salt Lake.
sweet thanks, I'm building mine this week. But I'm bending 3" pipe and using an ARB top. You guys have some great Ideas!
1991 RRC 2 1989 RRC's 1998 RR P38A 1967 SIIA 88 1969 SIIA 88 1967 SII 109 1971 Vampire Radio Body 101FC |
#19 (permalink) | |
It's all about my Blue Balls!
Silly Boys!... Range Rovers are for girls! Cars: 1988 Range Rover Classic (aka Blue Balls) 2000 Discovery II SE7 (my fiance's... soon to be mine) |
#20 (permalink) | |
Rocky Mountain High
CALM DOWN....LMAO!!!!! You will be fine!!!! where you are moveing to there is noone to cut u off..LOL ![]() |
#21 (permalink) |
![]() Join Date: Dec 2005
Looks great Aaron!! Turned out real nice. I like the paint on it, Rhino line style.
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
#22 (permalink) |
Large Land Mammal
Ok, I may seem like an idiot for asking, but I have a mean green 88 rrc and the DIY snorkel has kept me at Home Depot for hours, looking at possabilities....My stupid question...Why is it facing backwards? I would think that it would be harder to get air in....maybe not while crawling but at freeway speed? I am thinking ram air into it.... As I piece mine together in the garage I keep thinking about that and figured I'd ask...
#23 (permalink) | |
#24 (permalink) |
Large Land Mammal
So, then my next question/suggestion would be that the PVC pipe, is it turnable or was it glued on? I am thinking of drilling a hole and putting on a wide clip so that I can pin it forward or pin it backward depending on conditions....
How does it work when it is backwards? Since my RRC can't go diving anyway, I am torn between the side vents and a snorkel..as the snorkel gets me fresh air, the other can get air and let out the heat... or maybe I do both and have 2 heat exhaust ports and 1 high level intake....hmmm |
#25 (permalink) | |
Rocky Mountain High
#26 (permalink) |
Large Land Mammal
Same here...I saw the talk of the RR sport vents, but I would like to see them closed....My family is big on the MGA's/B's and spitfires, so I have been looking at some of their little trap doors. I had to explain that a RRC is a british vehicle and that wheeling is a sport...so I did own a brit sport car.
If I could just mount 2 tracks inside the hood, spot glue them in, you could use a 2nd hood to make a sliding door behind the vents, or even just louver it, then in the winter pop the hood and slide them closed....Or, judging by the talent on these pages, run a remote lever to pull/push from inside the cab...maybe even a little servo motor.... Ok, back to work. ![]() |
#27 (permalink) |
Not to diss your PVC design there, but if you dont have some kind of cap that will divert water, that intake is going to suck in alot of H2O whenever you drive in rain!!
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done." |
#28 (permalink) | |
Rocky Mountain High
That's the plan..... the top piece is only temporary |
