Old 09-12-2006, 01:24 PM   #16 (permalink)
Rocky Mountain High
Funrover's Avatar
Originally Posted by sevenrover
Hey, so is it a 45 degree angle at the bottom of the windshield? Where it enters the cowl panel thingy? And what did you use to get a good cut?
it's not exact 45 angle but 45 does work!!!!! To make a cut I used a 2.75" hole saw!!!!!
Old 09-12-2006, 02:14 PM   #17 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Use a dremel with a cutoff tool, much cleaner cut.
Old 09-12-2006, 04:43 PM   #18 (permalink)
I'd Rather Push a Landrover than Drive a Jeep
sevenrover's Avatar
Location: Durban, South Africa, 'til 2009. Then Back to Salt Lake.
sweet thanks, I'm building mine this week. But I'm bending 3" pipe and using an ARB top. You guys have some great Ideas!
1991 RRC
2 1989 RRC's
1998 RR P38A
1967 SIIA 88
1969 SIIA 88
1967 SII 109
1971 Vampire Radio Body 101FC
sevenrover is offline   Reply With Quote
Old 09-13-2006, 09:10 AM   #19 (permalink)
It's all about my Blue Balls!
JungleRR's Avatar
Originally Posted by Funrover
No clue..I doubt it....... But no you are haveing 2nd thoughts? I know you will enjoy it here....... Me and Jess are here... and Ryan, jon, Amy, etc etc etc......Party at your barn!!!!!!!!
NO no second thoughts.... I'm still coming out.... counting the days.... I can't take seattle anymore... I'm so sick of the traffifc. I flipped off seven people when I drove less then five miles because I kept getting cut off and yelled at. I hate seattle... I tell ya for sure!
Silly Boys!... Range Rovers are for girls!
Cars:
1988 Range Rover Classic (aka Blue Balls)
2000 Discovery II SE7 (my fiance's... soon to be mine)
JungleRR is offline   Reply With Quote
Old 09-18-2006, 09:05 PM   #20 (permalink)
Rocky Mountain High
Funrover's Avatar
CALM DOWN....LMAO!!!!! You will be fine!!!! where you are moveing to there is noone to cut u off..LOL
Old 09-19-2006, 04:22 PM   #21 (permalink)
RageRover's Avatar
Looks great Aaron!! Turned out real nice. I like the paint on it, Rhino line style.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 09-20-2006, 09:26 AM   #22 (permalink)
Large Land Mammal
astateofmike's Avatar
Ok, I may seem like an idiot for asking, but I have a mean green 88 rrc and the DIY snorkel has kept me at Home Depot for hours, looking at possabilities....My stupid question...Why is it facing backwards? I would think that it would be harder to get air in....maybe not while crawling but at freeway speed? I am thinking ram air into it.... As I piece mine together in the garage I keep thinking about that and figured I'd ask...
astateofmike is offline   Reply With Quote
Old 09-20-2006, 10:22 AM   #23 (permalink)
rmuller's Avatar
On my DII's safari snorkel, I leave it face forward for road/highway, but as soon as I get offroad, I turn it around.. gets less dust in it, and if water splashes up, it wont come through as easily..
Old 09-20-2006, 10:39 AM   #24 (permalink)
Large Land Mammal
So, then my next question/suggestion would be that the PVC pipe, is it turnable or was it glued on? I am thinking of drilling a hole and putting on a wide clip so that I can pin it forward or pin it backward depending on conditions....
How does it work when it is backwards? Since my RRC can't go diving anyway, I am torn between the side vents and a snorkel..as the snorkel gets me fresh air, the other can get air and let out the heat... or maybe I do both and have 2 heat exhaust ports and 1 high level intake....hmmm
Old 09-20-2006, 02:16 PM   #25 (permalink)
Rocky Mountain High
Funrover's Avatar
Mine is turnable..... While on the HWY I trun the cap the other way....... I haven't noticed really much difference yet though!!! I may also do side vents in my hood to let out heat...we'll see...... I have to figure out how to cap them in the winter before I add them to cool it in the summer!
Old 09-20-2006, 03:32 PM   #26 (permalink)
Large Land Mammal
Same here...I saw the talk of the RR sport vents, but I would like to see them closed....My family is big on the MGA's/B's and spitfires, so I have been looking at some of their little trap doors. I had to explain that a RRC is a british vehicle and that wheeling is a sport...so I did own a brit sport car.
If I could just mount 2 tracks inside the hood, spot glue them in, you could use a 2nd hood to make a sliding door behind the vents, or even just louver it, then in the winter pop the hood and slide them closed....Or, judging by the talent on these pages, run a remote lever to pull/push from inside the cab...maybe even a little servo motor....
Ok, back to work.
Old 09-21-2006, 08:59 PM   #27 (permalink)
Nomar's Avatar
Not to diss your PVC design there, but if you dont have some kind of cap that will divert water, that intake is going to suck in alot of H2O whenever you drive in rain!!
The mere fact that a flame thrower even exists is proof that sometime, somewhere, somebody said to themselves, "You know, I'd like to set those people over there on fire, but I'm just not close enough to get the job done."
Nomar is offline   Reply With Quote
Old 09-21-2006, 09:53 PM   #28 (permalink)
Rocky Mountain High
Funrover's Avatar
That's the plan..... the top piece is only temporary
