RRC Owner in training
I am experiencing a drag on my drive line that I can't locate. I have checked diffs and changed fluids, tranny is topped up and working good (fingers crossed after my rebuild), CV joints seem good (topped up fluid). It is almost like a brake dragging...and yet all four corners check out ok. E-brake seems to be free...I don't think it's creeping on.
![]() My only guess is that mabey my T-case viscious coupling is starting to fail...however I do not notice any excessive steering pressure on pavement. What's the best way to check to see if the viscious coupling is locked up? ![]()
...But we in it shall be rememberèd; We few, we happy few, we band of brothers; For he to-day that sheds his blood with me Shall be my brother... 1994 RRC LWB, 82k miles, 4.2, Cornish Cream/Lightstone Interior, spring converted. |
Well, after driving some more today I have noticed that I am getting more steering resistance...which leads me to believe that my T-case VC is locking up.
So, no more driving and I will drain the fluid and take a look...will it smell burnt like a tranny does? Debris? Can I drop out the front propshaft to check function of the VC? Can you drive with a locked up VC and NO front propshaft? (I suspect not). If it is bad, I think I will go with a D1 LT230T...Mostly because the local boneyard has 2 that they will deal on. As I understand it, I will need X-case, Front propshaft, X-case mounts, Shifter...anything else? Rear propshaft? ![]()
I'm having similar issues w/ my '93 RRC. I too have narrowed it down to the VC. Weird thing is that I have no problems driving in the rain. I tried driving in a circle to see if any wheel lock up but I get nothing. I do feel a drag from the VC. It's just as noticeable going in a straight line.
As far as the LT230 conversion goes, I don't think you need to replace either prop shafts. I could be wrong on that. Don't forget that you have to butcher the center console a bit to accommodate the new lever movement.
Abraham 1993 RRC LWB 1995 RRC LWB ![]() I run, play, fix and live Rovers because I choose to. |
Yes...straight line symptoms are like its in...well...4 wheel drive. Steering was lets say...more resistant...required more pressure to move steering wheel. I was starting to get a little wheel hop/steering jerkyness on paved turns too. Didn't notice it so much on dirt though...for obvious reasons. Oh...much more noisy too.
BTW, you will need: the front drive shaft, frame mounts, shifter linkage, and a pre 96 output shaft if the LT230 is from a post 96 D1
#6 (permalink) | |
Paul Grant is the man for parts. He's always first on my list.
Yep...already talked w/ Paul.
Anyone have any thoughts on what I'm describing here?
#9 (permalink) |
Rebuilding Rover
other than I know what you mean mines been doing it for years. I have no idea what the problem is though never been able to pin point it.
I have decided that sooner or later whatever it is will break lol
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
#10 (permalink) |
fuddmucker
ummmmm.... i'm going to sound really dumb, but here goes anyway. is your steering shock all bent in? mine was pretty whooped on and i was gettin the same kind of resistance. took a look and my shock was pretty hurtin. havnt replaced it yet, but it drives alot better.... good luck man, wish i could be of more help
#11 (permalink) |
I'll take a closer look at the steering stabilizer...but I think it's ok.
I'm going to pull the front propshaft this weekend and see if that makes a difference.
| Thread Tools | |
| Display Modes | |
| HD track rods and drag links from QT for D2 | fivespddisco | Land Rover Parts and Accessories | 0 | 04-13-2008 10:09 AM |
| Driveline Issues need help!!! | mdvickst | Range Rover Classic | 0 | 07-12-2007 03:13 PM |
| Engine treatment - Mystery Oil | me.guevara | Discovery Series I | 18 | 01-03-2007 01:10 PM |
| Intermittent Driveline Vibration at 60MPH | AdrianL | Range Rover Classic | 10 | 06-24-2005 07:52 AM |
| What is a drag link and what does it do | ilamU_Kevin | Discovery Series I | 7 | 05-25-2005 05:39 AM |
