Links
Old 04-30-2005, 06:25 PM   #1 (permalink)
Default Need help asap brakes (abs) bleeding pro.
I am have a serouis problem with bleed ing my brakes and now there is no pressure in the brake system and need to know how to get it back. If you have any ideas it would be great. Its a 93 Country LBW RR w/ABS and if any one knows how any info would be helpful.
Decker is offline   Reply With Quote
Old 05-01-2005, 04:11 AM   #2 (permalink)
Super Moderator
Disco's Avatar
Hi Decker! You could try this site.Just scrol down till you get to "brake bleeding". http://www.norcalrover.org/downloads/ncrc_6.pdf
Good luck.
Old 05-02-2005, 06:48 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
What is happening when you open the valve?
Are you getting fluid out of it?
I punch my clown daily.
Old 05-02-2005, 02:45 PM   #4 (permalink)
Default all fixed
I got it done I was not able to get any pressure in the brakes and I thought to my self what if I used the accumulater to make pressure and I put the key in the on slot and pushed the petal and then it made pressure. It is kind of a self bleeding system. When you turn on the accumulater it pumps fluid out at great rates so no more problems with the brakes. THANKS for your help now on to the next problem. bye for now
