Old 03-02-2005, 06:03 PM   #1 (permalink)
Default New to the forum and brake problem help
Hello fellas!!! I'm new to the forum and I have never imagined that theres a Land Rover forum out there. I hope to learn alot from you Land Rover Experts!!!!!
I have a problem with my '99 Range Rover 4.0 HSE. While I'm driving for awhile the brake light comes on and then I get "Brake Fluid Low" msg on my dash. I checked the brake fluid resovoir and it is full. The car brakes normally. Sometimes when I pump the foot brakes the msg. warning goes away.
Do any of you guys know what could be the problem.
Thanks in advance for any responses!!!
RoverCR is offline   Reply With Quote
Old 03-02-2005, 06:15 PM   #2 (permalink)
Probably your brake fluid level sensor is defective.
lonestarrover is offline   Reply With Quote
Old 03-02-2005, 07:02 PM   #3 (permalink)
Do you know where the sensor is located??
Old 03-02-2005, 09:09 PM   #4 (permalink)
LRO Founder
Serg's Avatar
Should be attached to the brake fluid reservoir. That is usually where it is located. Disconnect it, carefully, and spray some cotact cleaner on the fire loom where it plugs into the reservoir. Don't overspray it, just a bit.. Clean it off and plug it back in. See if that helps. If not, your sensor is most likely defective.
Serg
Current Vehicles:
2003 BMW 540iT M Sport
2005 BMW R1200GS
2004 Element Skateboard (Indy trucks, Bones Swiss, etc...)
Past LR's:
1995 Range Rover LWB Classic
1997 Discovery XD
1995 Range Rover LWB Classic 4.0
Serg is offline   Reply With Quote
Old 03-03-2005, 12:59 AM   #5 (permalink)
Landy-Andy's Avatar
Default Brake fluid.....
Hi RoverCR,
Welcome to the forum.
Its good advice to check out the sensor first.
If that doesn't do it another thing that can give you errors on your braking system is old/bad fluid!
Its worth checking your service records to see when (or if) the fluid was last changed. I believe LR recomend every 48K?
good luck,
Andy
Landy-Andy is offline   Reply With Quote
Old 03-07-2005, 06:08 PM   #6 (permalink)
glenncof's Avatar
I always carefully read owners manual for indicator lights. Sometimes they do multi-function. Yours seems direct though. Read manual anyhow. I agree with faulty sensor or wiring.
glenncof is offline   Reply With Quote
Old 03-08-2005, 07:02 AM   #7 (permalink)
troverman's Avatar
Your best bet is drain and change the brake fluid entirely, then bleed the system. Your fluid could be no good, or more likely there is air in the line. You could try just a bleed job, which is fairly straightforward.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
