Your best bet is drain and change the brake fluid entirely, then bleed the system. Your fluid could be no good, or more likely there is air in the line. You could try just a bleed job, which is fairly straightforward.
Current:
1992 Range Rover County
1995 Range Rover 4.0 SE
2000 Land Rover Discovery II
Also current:
1995 Mercedes-Benz E320 Wagon
1999 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
