Old 09-19-2006, 08:13 PM   #1 (permalink)
Exclamation No Start. Help I need to get to work.
I have an 89 Classic. It stalled out at a stop light after about 5 mins of driving, needed gas put some in it and after that it would start sometimes and when I would give it gas it would die out. This is what I have done so far in order. Drained the gas, (do not know why) nothing happened. Checked the fuel pump and filter it is all good. Changed the Idle control valve, nothing changed. Changed spark plugs, started up like a charm, then back to dying out. Changed coil, nothing happened. Changed Idle control module, nothing changed. Changed dist cap, nothing. The car will not even start now, at first it would start and idle erratically, give a little gas no problem, lay the hammer down and it would die. Now it will not even start. There is a little blue spark occassionally on the plug but it is very small and erratic. I do not have the tools or for that matter even know what to do to test the output of the wires and the like.
Please help me I have gone as far as I can. Maybe it was a bad decision for a daily driver, but I always had like this car and it was a graduation present to myself.
I have also checked all of the fuses in the fuse box and they are all fine...any suggestions,
Frustrated,
Robbie
robbiewsmith is offline   Reply With Quote
Old 09-19-2006, 08:42 PM   #2 (permalink)
Alternator! I'll bet $$$ on it
tlry00 is offline   Reply With Quote
Old 09-20-2006, 08:57 AM   #3 (permalink)
I'd Rather Push a Landrover than Drive a Jeep
sevenrover's Avatar
Location: Durban, South Africa, 'til 2009. Then Back to Salt Lake.
Yeah, I would say, alternator, MAF, or ECU, but your MAF and ECU are highly unlikely.
1991 RRC
2 1989 RRC's
1998 RR P38A
1967 SIIA 88
1969 SIIA 88
1967 SII 109
1971 Vampire Radio Body 101FC
sevenrover is offline   Reply With Quote
Old 09-20-2006, 02:01 PM   #4 (permalink)
WWTSD? (what would Tony Soprano do?)
stevo-II's Avatar
So is the stock ignition system on the RRC just really sensitive to the voltage level supplied to it??? - ie does it work fine at 13.8 volts and then crap out at 12V - I read on rangerovers.net about a guy who swapped in a MSD setup - supposedly it was stable at down to 5-6V or so, this guy claimed that eliminated the driveability issues with a marginal alternator.....
Steve
2001 D2 -The Stevo-II
1992 RRC-The Stevo-I
stevo-II is offline   Reply With Quote
Old 09-20-2006, 04:44 PM   #5 (permalink)
So how would an alternator, cause there to be no spark on the spark plug? Especially with no previous charging problems? If I jump it off it won't run either.
Old 09-20-2006, 06:48 PM   #6 (permalink)
OkieRover's Avatar
Gallery: 2
So do you have spark at the coil?
Do you have spark on the plugs?
Check the fuses.
I punch my clown daily.
Old 09-20-2006, 07:20 PM   #7 (permalink)
yes I have spark at the coil, but no or very little spark at the plug, So what fuse might it be? - other than the ones in the dash?
Old 09-21-2006, 01:40 PM   #8 (permalink)
OkieRover's Avatar
Gallery: 2
I was thinking the ones in the dash.
So the coil spark is a nice and healthy one?
Old 09-21-2006, 04:53 PM   #9 (permalink)
yeah the coil is brand new, however the rotor on the distributor seems to be stuck, in the manual it says that that the distributor rotor should move then spring back due to a spring in the distributor, have any of you ever heard of that?
Old 09-23-2006, 08:26 PM   #10 (permalink)
Thank you for your posts, but I fixed it today!! needed a new rotor on the distributor...should have checked that first but now the car has alot of new parts!!! Oh yeah if you need a idle control valve you can get one just about anywhere...it is the same as an 89 Astro Van...imagine that.
Old 09-23-2006, 10:26 PM   #11 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
I imagine if you to the ford Dealer and buy one for the Astro van, it would be half as much........
Thanks for that data though....good to know...
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
Old 09-24-2006, 09:21 PM   #12 (permalink)
OkieRover's Avatar
Gallery: 2
The Air Idler is also the same as a 95 S-10. And cheap that way.
