Old 05-29-2007, 03:23 PM   #1 (permalink)
ObraViva's Avatar
Default Noise when it's turning to the right.
Hi there, somebody can help with that?
Every time when I turn to the right on a bump street I read a strong metal like scraping sound coming from the left side. When I turn on a flat smooth street nothing happens. Nothing happens when I turn to the left.
I'm using stock tires.
I checked the suspension, springs, shocks.....and look ok.
Any comments?
Thanks for the good work, the forum is great.
ObraViva is offline   Reply With Quote
Old 05-29-2007, 09:32 PM   #2 (permalink)
OkieRover's Avatar
Gallery: 2
Does your swivel housing have enough grease?
Sounds like you might be loosing a CV joint.
You should also look at the splash guard for the disc brake. It can rub on turns and sounds horrible when in fact it just needs a bit of adjusting.
I punch my clown daily.
Old 05-30-2007, 04:49 PM   #3 (permalink)
Denny's Avatar
Gallery: 1
Check your wheel bearings, if you haven't changed the grease in a while it might be time anyway.
Denny is offline   Reply With Quote
Old 06-02-2007, 05:01 PM   #4 (permalink)
ObraViva's Avatar
Ok, there is a diference when you turn on a flat paviment and a bump one? The cv joint is encapsulated , diferent of the indepent suspension???? To let you guys know that only happens on a right turn on a bump paviment!!! I'll check the splash guard and the grease on the cv. thanks guys.
