ok so what will $700 do? - Page 3 - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 07-21-2012, 05:33 PM   #31 (permalink)
90 red rover's Avatar
so now i have a few questions. one where is the best place to get an o2 and is there a way to check them to see of that is the problem. and 2 what the heck is going on with the timing? how can you tell if it the vacuum advance is working and how can you distinguish between vacuum and mechanical advance from the timing light?
Brian
1990 RRC
1996 Toyota Avalon - hers
1989 F-250
1994 Toyota Pickup
90 red rover is offline   Reply With Quote
Old 07-21-2012, 11:51 PM   #32 (permalink)
roverandom's Avatar
There is good info on replacement parts as well as parts interchange sources to be found on Range Rover Parts Sources, Land Rover Discovery Parts Sources
Vacuum advance can be tested with a pump or by simply sucking on the hose connected to the diaphragm and noting a change in RPM.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline   Reply With Quote
Old 07-23-2012, 11:29 AM   #33 (permalink)
thanks random, there is lots of info in there. i am wondering what the drawbacks could be for the cheaper replacements vs. the ngk's. anyone had any experence with these generic o2's?
Replacement USOS-4000 Oxygen Sensor | Auto Parts Warehouse
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 08-22-2012, 08:30 PM   #34 (permalink)
ok so i bit the bullet and bought NTK sensors. bought both at 87 each through rock auto. they came today and i just finished installing them. no change in performance. it still ran a 31 sec 0-60. but it felt stronger and there was no misfiring and no other ill effects just a dog. i did notice that it was especially doggy at the low end, like it bogged down right at take off then got stronger at about the 5 sec (10 mph) mark i didnt mark rpm but i could get it easy enough next time i drive it. i then came back to the garage and checked timing. still at 4-5 btdc, so i changed it to 9 btdc and ran it again. 26 seconds. so i am thinking that my timing is not functioning properly. when i suck on the vacuum hose to the dist diaphragm it does nothing to the rpm or sound. when i goose the throttle i can watch the advance go up.
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 08-28-2012, 01:34 PM   #35 (permalink)
so i checked it yesterday and the rpm boggs down from just off idle to about 1800ish rpm at about 15mph. i jumped the base timing to 12 deg BTDC and noted very little change in the time, so no performance gain. the bogging was about the same too. i am confused about where to go from here and need some help.
i sukked on the vacuum hose with the cap off and the cover off and i can see the timing plate trying to move does that mean it is working or not?
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 09-23-2012, 06:09 AM   #36 (permalink)
ok, just to bring everyone up to speed. i replaced the distributor with a new one from D&D (pertronix). the performance gain was significant taking the 0-60 from 26 sec down to 20.5 seconds! so i am pretty happy with that! but it still seems to be missing something. i think that i will turn my attention to fuel next. get a pressure gauge and see what the fuel pressure is at. then maybe look at the bosch mustang injector swap?
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 11-10-2012, 08:42 PM   #37 (permalink)
just ordered the bosch gen 2 injectors for the swap. i think that i can check the fuel pressure tomorrow and that will hopefully tell me something. i am thinking that i will t into the line downstream of the fuel filter. i checked the vacuum on the fuel pressure regulator and it wasnt leaking but i was un-able to discover anything else. is there a was to check its function?
i also ordered a set of 2781 ome springs since mine are starting to sag in the rear.
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 11-14-2012, 09:04 PM   #38 (permalink)
I dont know if you have heard of this before, but there is an iphone app called dynolicious that puts out pretty good results as long as you put in all the information about your vehicle. it does 0-60 time and hp/tq. I used it on my past subaru and it seemed to work. Just a thought. I too am looking to increase the performance on my 93 rrc just to try to get it to a more respectable acceleration. Interested to see how things turn out!
cormachm869 is offline   Reply With Quote
Old 11-15-2012, 11:28 AM   #39 (permalink)
cdb
Couldn't find that iPhone app and it sounds very interesting.
CDB
1995 RRC
2004 RR HSE
2001 GMC 3/4 4wd P/U
2003 Discovery 2
2001 Porsche C4
1989 Cadillac Allante
cdb is offline   Reply With Quote
Old 11-15-2012, 01:52 PM   #40 (permalink)
at lunch today my friend told me to get "adyno" for android (the phone that i have). i will download this when i get home and post up some numbers on what it says and how it compares to my super accurate wristwatch-stare-at-the-speedo method. i am a little excited about the hp and torque numbers also; though i am not holding out much hope for its accuracy!
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 12-04-2012, 08:33 PM   #41 (permalink)
just an update. i re-baselined the rover last night 0-60 came in at 19 seconds. thats minus 1 from before - yea for cold and dense air! i removed the injectors after that and just finished putting the new ones back in. i will re-run the 0-60 tomorrow night after work. i tried the phone dyno thing to no avail. it needed a specific angle to work and i couldnt hold it in that angle and get it to "calibrate" so i gave up. i will let yu know about the injector upgrade results. here are a few pics
ok so what will 0 do?-img_0324_mod.jpg   ok so what will 0 do?-img_0321_mod.jpg
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
Old 12-05-2012, 08:18 PM   #42 (permalink)
well bummer. only changed the 0-60 by 1 second or so. it is also 20 degrees warmer tonight then it was 2 nights ago. but now it is running 18.5 seconds. i guess i should take what i can get though. it idles smoother but the hot start just a minute ago was pretty rough, so maybe i will dial back the timing advance a little. i am a little stumped at this point. not sure what to try next?
Brian
1990 RRC
1989 F-250
1994 Toyota Pickup
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
2,700+rpms small vibration 2003discoII Discovery Series II 9 01-14-2011 08:25 PM
1990 RRC Silver in CA $700 turtle123 Land Rover Vehicles 0 01-25-2010 01:39 PM
half shafts rated to 700 BHP the mad hatter Land Rover Parts and Accessories 23 06-21-2009 03:05 PM
F.S. 2004 Discovery SE- 29,700 miles 007 Land Rover Vehicles 1 12-14-2008 03:38 PM
FS: 1995 Discovery in S.C. $3,700.00 S1discoinSC Land Rover Vehicles 1 02-06-2008 03:27 PM
SEO by vBSEO 3.3.2
