Old 04-20-2008, 06:41 PM   #1 (permalink)
1998 Range Rover
Default p38 oil leak
I have oil leak, only while engine is running, it drips down the oil filter? Im using a fram oil filter and its turned as far as it'll go? Do i have to use a LR filter? or is there a bigger problem?
roverbryan08 is offline   Reply With Quote
Old 04-20-2008, 06:58 PM   #2 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
Ditch that FRAM filter as fast as you can...they have no anti-drainback feature and allow your motor to start with the top side "dry". VERRRRRY BAD!!
Go to your local NAPA store and get a NAPA GOLD filter (they are made by WIX...and are very good) and are only about $8-$10. I think its a #1068 for your RR...but you will want to check with the guy behind the counter.
Also, check to make sure your PVC valve is not blocked and causing your engine to pressurize and pump the oil out the path of least resistance...I've seen it happen (to a non Rover...but still a GM engine)
Support the Troops = Support the Mission
Don't say it if you don't mean it.
1994 RRC LWB, 82k miles, 4.2, Cornish Cream/Lightstone Interior, spring converted.
BullDogSix is offline   Reply With Quote
Old 04-21-2008, 01:22 PM   #3 (permalink)
1998 Range Rover
replaced the oil filter....didnt work, so PVC valve next. also, my oil is slightly high i believe, could this be causing it as well?
Old 04-21-2008, 01:58 PM   #4 (permalink)
1989 county 3.9
Just a thought... on mine there is a plug (just like the oil sump drain plug above the filter)
on the filter housing... it has a copper crush washer. 1 1/8" should tighten it up...if its dripping it could make the filter appear to be leaking.
MysteryTheatre is offline   Reply With Quote
Range rover P38 weird Oil leak problem pat3d Range Rover P38, Mk III and Range Rover Sport 12 04-26-2008 06:56 AM
Cylinder#6 Misfire & Coolant Leak tskim2024 Discovery Series II 3 02-09-2008 09:07 AM
What's up with that rover oil leak thing??? Steph Discovery Series II 16 09-02-2007 10:37 PM
craziness with the exhaust leak ealex Discovery Series II 4 05-18-2007 06:41 AM
Common coolant/oil leak area? 6cuda6 Discovery Series II 3 04-22-2007 01:09 PM
