ChamplianRover
Question: When I put the plenum back on I just put it on metal to metal and screwed those allen bolts tight. I didn't remember there being a gasket so I didn't even think of needing one or of sealing it with a liquid gasket of some sort.
Mistake, and the reason for the rough running, maybe? I feel like I can hear an air leak. Thanks, ChammplainRover 95 LWB X 2 |
Rebuilding Rover
If memory serves there is definitely a gasket in between the upper and lower plenum. It's a good chance you could have an air leak there without the gasket.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
#3 (permalink) | |
You didn't remember a gasket because there was none. ![]() The plenum was seated originally at the factory using a liquid gasket maker called Blue Hylomar. Frankly you can used any gasket maker that remains flexible after setting. Torque (alternate bolts) carefully to spec. (11 nm) James |
ChamplianRover
Thanks.
I've been out to the rig already. Lifted up the plenum and applied a (messy) bead of hylomar blue. Hope I created a thorough seal. Cure time overnight adequate? If so, I'll report in the morning how she runs. Thanks again. CR |
#5 (permalink) | |
Overnight will be fine. If you are chasing a vacuum leak. get a spray can of ether (Quickstart) With the engine running, lightly spray on suspect areas. If the rpm alters at any place, (away from the air intake) you have found your demon. James |
| Thread Tools | |
| Display Modes | |
| multiple coolant leak issues | akabaa | Discovery Series II | 6 | 06-09-2008 08:44 PM |
| Range rover P38 weird Oil leak problem | pat3d | Range Rover P38, Mk III and Range Rover Sport | 12 | 04-26-2008 06:56 AM |
| What's up with that rover oil leak thing??? | Steph | Discovery Series II | 16 | 09-02-2007 10:37 PM |
| craziness with the exhaust leak | ealex | Discovery Series II | 4 | 05-18-2007 06:41 AM |
| Common coolant/oil leak area? | 6cuda6 | Discovery Series II | 3 | 04-22-2007 01:09 PM |
