LRO Founder
My owners manual for my 19995 Classic LWB says to use Premium Unleaded only... well that's fine and dandy for my M3.. heck it even gets 21 MPG when I romp on it.. However for my Rover (which gets a whopping 11-15mpg so far) I would like to use mid range or even regular unleaded..
Question is, will this hurt it?? I really can't see how since it is not a high performance engine... I just don't want to save a few bucks if it means engine problems down the line. Serg
Current Vehicles: 1995 Range Rover Classic LWB in Beluga Black 2005 BMW R1200GS 2004 Element Skateboard (Indy trucks, Bones Swiss, etc...) Past LR's: 1995 Range Rover LWB Classic 1997 Discovery XD 1995 Range Rover LWB Classic 1995 Range Rover LWB Classic 4.0 |
#4 (permalink) | |
It hurts, but do it. In a short while you will find a cheap gas station, like Arco, that sells good gas cheaper. Mike J. |
LRO Founder
No bigie... I use Chevron only anyhow, I was just wondering if the thing really needs to have Super Unleaded. No prob, thanks for the info guys!
Serg
FWIW, if you are looking to up your MPG, Change every oil in your car to synthetic and I mean everything. Lube your U's and CVs and get synthetic in the diffs. Less friciton is good. Do it yourself and save some cashish.
Get very good wires and plugs, 9.5mm or better. Do not go cheap. I put in a Jacobs Ignition kit, that added 2 mi per gal and gives better burn to your plugs. Then run the good gas.. long term it will be good for the fuel system. I have 300k mi on my white elephant 1988 RRC and I have been getting over 15 mi per gall all day on the highway. |
Last night's fill-up calculated at 15.5 mpg. My engine has 147,000 on it. I use Castrol 20w50 year around, changed every 3000 miles. I get the cheapest gas I can and use 87 octane. I try to remember to run a bottle or two of injection cleaner through it on every third oil change, just for fun.
#8 (permalink) | |
#9 (permalink) |
To say I am blessed with this engine would be an understatement.
It's the 4.2. Not sure about the compression. Other than me overheating it once or twice due to a clogged radiator I have tried to be good to it. My Rangie had 86,000 when I bought it in 2000. The worst mileage I have gotten was 13.9 the best was 19. That 19mpg was a highway trip in October 4 years ago. I drive a mix of city and highway with highway being 50 miles of my daily trips. I wish I could afford a 300Tdi. |
#10 (permalink) |
Hi
oakie, you said "I wish I could afford a 300Tdi."? Why? Are they a lot more expensive there in the US? Or is Diesel fuel more expensive hen petrol?
Thank you Joao Pedro Defender 90 Td5; 1966 88"SIIA |
#11 (permalink) | |
#12 (permalink) | |
I don't know why they are so expensive but they are. |
#13 (permalink) | |
#14 (permalink) | |
LRO Founder
Serg
#15 (permalink) |
The short-bore V8 aluminium block is pretty high compression, hence you'll pretty easily get the dreaded knocks with anything below premium gas.
Also, bear in mind that European petrol starts at 90 octane, and goes up to 98/99 octane at the pump, as opposed to US 'cheapo' gas that is lucky to get to 92/93. |
