» Sponsors
» Sponsors
Old 11-04-2009, 07:44 AM   #1 (permalink)
nova's Avatar
Angry Radio on but no sound..please help
So I have a 95 Classic SWB with the Harmon Kardon system. The radio started acting up where I had to wait about 5 minutes for the sound to come on, and now the stereo turns on but I get no sound.
Can anyone tell me where to start to diagnose this issue. Is it most likely the head unit, amp, wiring....uhg!
Thanks for the help...
nova is offline   Reply With Quote
Old 11-04-2009, 01:32 PM   #2 (permalink)
Jeep Slayer
GoGetTheHorzion's Avatar
i would check the wiring, and the amp and all the connections
live fast die young
GoGetTheHorzion is offline   Reply With Quote
Old 11-09-2009, 07:45 AM   #3 (permalink)
Mine does the same thing.. the radio has power, and everything seems to come on, but no sound. Wierd.
ranger1968 is offline   Reply With Quote
Old 11-09-2009, 03:19 PM   #4 (permalink)
carlosz's Avatar
use a vohm (voltage ohm) meter to find if you have output from the radio to the amp input that is both ohms (sound) and power once that is stablished or eliminated, you proceed to amp output. remember there are grounds to be checked as well.... 8ohms and 12 volts or 5 millivolts are normal outputs.
ohms is for speaker, volts or milliamps are power to amp...there is a remote on power wire which turns the amp on and off and a costant on supply as well as grounds...
carlosz is offline   Reply With Quote
Radio works but can't hear sound anngybee Range Rover P38, Mk III and Range Rover Sport 7 11-16-2009 09:13 PM
Radio works, but no Sound out of speakers? FastMoney Discovery 3 / LR3 2 10-26-2009 12:08 PM
94 LWB Radio Question - No RH Sound christof Range Rover Classic 2 06-08-2009 01:42 PM
Replaced radio but still no sound (has power, though) flyfishinbum Discovery Series II 3 02-16-2009 12:09 PM
92 RRC aftermarket radio install-NO SOUND??? Roverranger Range Rover Classic 2 12-05-2005 05:54 AM
