Rangie Ute (Pickup) project - Page 9 - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-24-2012, 09:20 PM   #121 (permalink)
Ian Matthews
p76rangie's Avatar
Originally Posted by ArmyRover View Post
I'd like to see it finished before I retire. You have 5 more years
I would have said no worries in that timeframe, but Landrover keeps on sending me curve balls.
You would think that it would be a simple job to unbolt the old fuel tank and fit the one out of the 93. NOT SO!! Brackets are in completely different spots. So on the cross member just behind the rear diff I have to cut off the old bracket which is on the rear side of the cross member and weld on a new one to the front side of the cross member. This is while laying on my back under the car and having to weld upside down. NOT HAPPY!!!
Then I have to weld new brackets on the side of the chassis to mount the loop that goes over the top of the tank.
Old 11-25-2012, 02:38 PM   #122 (permalink)
Don't you mean "Not Happy, Jane!"
Looks awesome so far. After all of that effort I would be terrified to drive it!
2004 DII SE7, OME Lift, ARB Bumper, 265/75-16's, The Family Car
1999 P38 4.6 HSE, 128,800 miles, working EAS, Sold!
99duxrr is offline   Reply With Quote
Old 11-25-2012, 06:33 PM   #123 (permalink)
Ian Matthews
p76rangie's Avatar
Last time I used that line on this site I had to explain it to everyone. Decided not to go through it again.
Just finish the main brackets for the tank, now I have to do the ones for the hoop across the top.
Old 11-25-2012, 09:25 PM   #124 (permalink)
Ian Matthews
p76rangie's Avatar
Well this fuel tank is officially giving me the sh1ts.
Finally got everything mounted. I already knew that the filler pipe on the new tank is 2 inch and the old filler 3 inches. So I would have to make an adaptor so the fill point would go into the tank.
What I was not expecting was that the filler points on the tanks being in completely different locations. The wheel arches on a 2 door a bit bigger than on a 4 door. They are good for 35's if you want. So the filler pipe on the 93 was just behind the wheel arch. But look where it ends up on the 2 door (photo 1). The blurry bit at an angle in the photo is the the metal section that holds the mudflap at the rear of the wheel arch.
The curved cut out in the side panel in the second photo is where the filler actually is.
So now I not only have to make an adaptor for the different size pipes, I have to make up a pipe that will go from the filler position the the tank pipe. Not Happy Jan.
But the last photo at least shows that the tank is in.
Rangie Ute (Pickup) project-1.jpg   Rangie Ute (Pickup) project-2.jpg   Rangie Ute (Pickup) project-3.jpg
Old 12-08-2012, 04:17 AM   #125 (permalink)
Ian Matthews
p76rangie's Avatar
Well the fuel tank and lines are now in. The hard part with the tank ended up finding a 2 inch fuel hose with a 90 degree bend in it to move the new filler position back to the old position. Could only find 2 such hoses in the world. It was just lucky that one of those manufacturers was here in Oz.
All the rear taillights, fuel pump etc are also wired up and working.
Another milestone reach ed today with the motor now bolted in. Even though i had spent a lot of time previously trying to bleed the clutch, it did not work. I had to come up with various creative ways to do it before finally getting it to work.
I have set myself a target for getting the thing to move under its own power. I am hoping to reach the target set, but will not tell you what that date is as I might jinx myself.
Old 12-08-2012, 04:31 AM   #126 (permalink)
Ian Matthews
p76rangie's Avatar
Photo of the motor as it came out of the 93 and then photos of it cleaned up ready to go into the ute.
Old 12-13-2012, 07:01 AM   #127 (permalink)
90 red rover's Avatar
man that motor is pretty! getting a project rolling under power is always a huge boost in motivation, so i am excited for you to get there also. i always tend to loose motivation in the middle when its still in parts and a long way from running.
Brian
1990 RRC
1996 Toyota Avalon - hers
1989 F-250
1994 Toyota Pickup
90 red rover is offline   Reply With Quote
Old 12-13-2012, 11:28 PM   #128 (permalink)
Ian Matthews
p76rangie's Avatar
Getting there. Been doing some alloy polishing.
Wife pinched the camera, so these shots are from my phone.
Rangie Ute (Pickup) project-1.jpg   Rangie Ute (Pickup) project-2.jpg   Rangie Ute (Pickup) project-3.jpg   Rangie Ute (Pickup) project-4.jpg
Old 12-19-2012, 11:08 PM   #129 (permalink)
I sure like the way the guages in the cluster came out.
Rays Rover is offline   Reply With Quote
Old 12-23-2012, 05:07 AM   #130 (permalink)
Ian Matthews
p76rangie's Avatar
Hopefully I will get the motor fired up tomorrow. Just a few minor things to finish off. It won't be ran for long as I still have to work out an exhaust system and therefore it will be a bit loud.
Old 12-23-2012, 10:49 PM   #131 (permalink)
Ian Matthews
p76rangie's Avatar
ITS ALIVE!!!!!!!
The bitch fought me all the way, but i won. First, I turned over the motor for about 30 seconds to try and pump some oil through. Then went to turn it over again and nothing happened. Ended up the starter decided to pack it in. So to the shed to get another one and fit it.
Next, could not get any fuel pressure. I had tested the fuel pump before fitting it, so tried everything else first. No luck, had to drop the fuel tank (now half full of fuel) and pull the pump. Got it onto the bench and managed to get the thing running. Refitted it, but again no fuel pump working. So pulled it again. The pump would run upside down but not the right way up. Had a spare fuel pump, but the wiring plug was different to the one in there. So I had to pull the actual pump out from one and fit it to the other. Of course none of the internal wiring was the same either.
You should never test a fuel pump on the bench while it is still covered in fuel. Spark from touching wires to the pump ignites the fuel and your hand and pump end up in a ball of flame. No hairs left on my hand now.
Fitted the new custom made pump and managed to get fuel pressure by hot wiring the power to the pump, but not when running through the relay. So checked all the wiring, etc and it seemed OK. It ended up being a faulty relay.
After all that, it burst into live. As it had no exhaust, it said hello to the world in a loud voice. This thing had not ran for a few years before I got it, so it is the first time it had a heart beat in a long time.
Old 12-24-2012, 09:23 AM   #132 (permalink)
roverandom's Avatar
Glad you managed to get the old girl going in the end.
Merry Xmas!
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline   Reply With Quote
Old 12-24-2012, 10:49 AM   #133 (permalink)
sweet home chicago
ArmyRover's Avatar
Got any pics or vids of this part
Glad your alright and it's running
"If you can't stand behind our soldiers, then by all means stand in front of them." unknown author.
Need Parts?
PT Schram pt@ptschram.com
willtillery@roverguy.com
paulgrant@mac.com
www.lucky8llc.com
PM Marty(Drillbit)http://www.landroversonly.com/forums...o=newpm&u=5940
PM Original Rover Dude http://www.landroversonly.com/forums...do=newpm&u=708
1983 Land Rover 110 5 door wagon
1972 MGB
Old 12-24-2012, 02:58 PM   #134 (permalink)
Ian Matthews
p76rangie's Avatar
I am glad that both of you thought it was funny. No, I don't have a video of me running around the garage, waving my hand and trying to put out the fire.
Old 12-24-2012, 04:19 PM   #135 (permalink)
sweet home chicago
ArmyRover's Avatar
What do you want we established you're ok, commented that we are glad you're ok, then proceeded to make fun of you
Sounds like it would have made a good video though lol
Need Parts?
paulgrant@mac.com
www.lucky8llc.com
1972 MGB
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover Classic
Rangie Pickup (Ute) project p76rangie Show it off 34 05-05-2010 06:37 AM
1972 109" crew cab pickup project FOR SALE!!!!! mrrover Land Rover Vehicles 2 03-19-2010 05:33 PM
Classic UTE / V8 Lexus Landy/Lexus Range Rover Classic 0 09-28-2007 05:14 AM
Purchased a Series 3 LWB Ute DickFox Series Land Rovers 2 03-17-2005 01:29 PM
SEO by vBSEO 3.3.2
