Old 05-14-2008, 04:16 PM   #1 (permalink)
ChamplianRover
Default Ready to swap them...
The old exhaust manifold gaskets for new ones, that is.
Do I have to drop the whole exhaust, or can I remove the bolts, insert the new gaskets, then bolt back on.
Any step-by-step words of wisdom would be much appreciated.
Thanks,
ChamplainRover
ChamplainRover is offline   Reply With Quote
Old 05-14-2008, 07:23 PM   #2 (permalink)
GreatDivide1's Avatar
no you dont have to dropthe whole exhaust..... i just did a gasket swap the other day with out droping the exhaust.... just unbolt it all then bolt the manifold to the head first then to the cat pipe and all will be good...
91 G.D.E. project/daily winter driver
93 BMW 325i project/daily summer driver:SOLD:
00 BUELL cyclone custom
http://www.snhlr.org/
GreatDivide1 is offline   Reply With Quote
Old 05-15-2008, 05:56 AM   #3 (permalink)
^^What he said x2...It's easy. Don't forget to use lots of antiseize on everything you loosen and put back together.
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (only the cab shell & rear bumper is original), '62 International 404 tractor (red & white) & many other project cars in the past!
57loboy is offline   Reply With Quote
Old 05-15-2008, 10:24 AM   #4 (permalink)
It's not broken, it's just not fixed yet.
Beard's Avatar
start spraying PB blaster 5 mins ago.
might even call for kroil.. "the oil that creeps"
Project Rover Page
Beard is offline   Reply With Quote
Old 05-15-2008, 10:33 AM   #5 (permalink)
Beard - nice lookin' RRC you have there... May I be so bold as to suggest that you start a new thread here updating us on your progress as you do the work. The photo documentation so far is off to a good start. I am sure you'd get a ton of interested followers, including me!
02 navigation swap mx3mike Range Rover P38, Mk III and Range Rover Sport 2 03-16-2008 09:15 AM
150 AMP Alternator 4 Swap into pre 93 SWB RR hamrendan Range Rover Classic 1 12-06-2007 07:06 PM
150 AMP Alternator 4 Swap into pre 93 SWB RR hamrendan User Ebay Links 0 12-05-2007 10:54 AM
How feasible would a Cummins 5.9 swap be? Angel of Death Series Land Rovers 32 11-09-2005 10:44 PM
150 AMP Bosch Alternator Swap hamrendan Range Rover Classic 9 02-12-2005 01:00 PM
