Old 04-21-2008, 06:41 AM   #1 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Default Rear axles
So last night I head into the garage to grab a few things for the wife and I drop a roll of paper towels. They roll over against the rear wheel of the parts RRC. As a lean down to grab them through the open center of the rim I notice that the axle cover is missing and I can see the end of the shaft. I start to stand up when it dawns on me that there seem to be more than 10 splines on this end of the axle. I count them and end up with 24 (yes I did have to take my shoes off and unzip my fly to count that high).
So the question is would that be evidence of a 24 spline set up? I 95% sure I know the answer I just want to confirm it before I do the happy dance!
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 04-21-2008, 04:12 PM   #2 (permalink)
So what you are saying is that the drive member was off the rear wheel and you could see the outer end of the rear axle, correct? All the ABS equipped RRC's had 24 splines at the drive members. It's the inner spline count that matters when you're figuring out what diffs you have. My bet is you have 10 splines at the diff. I have never seen a 24 spline rear (at the diff) with removable drive members. Every 24 spline rear axle I have ever seen from the factory was a one piece deal with the drive member permanently attached to the half shaft.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 04-21-2008, 04:16 PM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
damn you ruined my happy dance Paul.....
http://snhlr.org/
90 RRC Parts truck
Old 04-21-2008, 04:20 PM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
If the drive flange has been removed, the axle should just come straight out. So you can pull it out and have a look.
After market axles have drive flanges on 24 spline axles.
spline count on rrc's..... daway Range Rover Classic 8 06-29-2007 07:37 PM
Scorpion Racing Rear Bumper Install w/pics. beavis4g63t Discovery Series I 10 10-17-2006 01:38 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
Oh man...(flame suit is on) 02disco2 The Lounge 9 03-27-2006 11:51 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
