Old 03-15-2008, 07:50 AM   #1 (permalink)
1990 RRC
gregory.pearson's Avatar
Default Rear Rotors
Hey everyone,
Here is a quick classic newbee question.
I have the correct replacement rear rotors from our friends at R.North. I have changed all of her brake pads before and am familiar with that basic operation.
Could someone take the few seconds I'm sure are only required to walk me through the process of unbolting/freeing these rear rotors? I'm fairly educated on most the unique angles of our axles thanks to you guys... But I'd rather not be crossing anything up on such a novice maintence operation.
Much thanks in advance. you guys rule.
greg
gregory.pearson is offline   Reply With Quote
Old 03-17-2008, 05:15 PM   #2 (permalink)
1990 RRC
Come on guys... all these views but not even one response?
Was it that bad of a question ?
I'll delete this if it is that bad
Old 03-17-2008, 08:40 PM   #3 (permalink)
Allrighty then......the following is conjecture based on educated guesses....
You don't give us a year......
The Rave disc gives no procedure for disc removal for either the ABS or non ABS version.....
The one line for caliper removal is "remove bolts and caliper" (this is after pad and ABS sensor removal).
I am assuming that the disc comes right off, just like many other vehicles.....the drawings show nothing holding them on......
Now you know what I know. I have never removed these suckers and I am 1100 miles from my tech-center, (fancy word for workshop) and Rover collection.
1962 SII-a 109 Mr.Toad
1991 RRC Parting out.....
1989 RRC Parting out....
Oscar is offline   Reply With Quote
Old 03-19-2008, 09:52 AM   #4 (permalink)
Eric D's Avatar
I too have a 90 RRC.
Remove the caliper mounting bolts, set caliper aside supported by a wire or bungee cord.
ROTORS:
You need to remove the dust cap, followed by the circlip.
Remove the 5 bolts holding the metal plate (aka Drive member), the paper gasket will be replaced with a new one. Make sure you have new ones handy.
Then you need a 52mm socket to remove the lock nuts.
You can find this socket from many on-line retailers (I have an 2 1/16" socket that works ok, it's a tad larger than the nuts).
There is a lock washer and keyed washer, the lock washer will be replaced with new ones, make sure you have them.
You'll see the bearings in the hub, just pull out the rotor and make sure not to drop the bearings.
Turn the rotor with lugs facing a table, You need to remove the 5 nyloc nuts and then the ABS sensor ring will come off. Clean the sensor ring of any debris.
Now you will see 5- 12point bolts that need to be removed. I used my 1/2 air gun to remove them.
I also made sure to remove any surface rust on the hubs mating surface.
Place new rotor onto hub and tighten the bolts.
Install the ABS sensor ring and use blue thread locker or fit new nyloc nuts.
Make sure the bearings are repacked with fresh grease, and that the seal is still serviceable. If in doubt, replace the bearings, races and seals.
Installation is the reverse of removal.
CALIPERS AND PADS:
Make sure you have the revised factory anti-rattle shims for the rear pads.
2 per each caliper, they are directional.
I've used several different brands of pads and they all squeak. I have even chamfered my pads with no success (works on my other cars thou). Oh and don't try to reuse the pad hardware, some pads come with new bars and springs, if not, they are cheap from the on-line retailers. Stick with genuine brand as some after market brands were made too short and you can't fit the cotter pins.
I should also say that you should inspect the condition of the caliper seals.
Now would be a good time to rebuild them. Knowing that most Rover owners are thrifty, they seem to neglect routine maintenance. The parts are not expensive, just takes time to do, but I like to have piece of mind when it comes to brakes.
Best of luck!
Eric D is offline   Reply With Quote
Old 03-20-2008, 10:28 AM   #5 (permalink)
Geoffrey F Miller's Avatar
This is how I did the hubs on my 1985 non-ABS model. There will be detail differences, but it gives the general idea. I didn't need to change the discs, but you can easily see what's needed.
http://www.geoffrey-miller.demon.co....hubs/index.htm
Also, do make sure that you have the ABS sensors properly fitted at the end, if you don't you'll get an error code which will mess up the system.
Hope it helps, but PLEASE do read the manual first for torque settings and safety issues.
Geoffrey
1985 4-door Range Rover Classic
Geoffrey F Miller is offline   Reply With Quote
Old 03-20-2008, 12:57 PM   #6 (permalink)
Oops.....Going to have to take another hard look at the manual....
Old 03-20-2008, 01:28 PM   #7 (permalink)
KevinNY's Avatar
Best way to hold the rotor while removing the bolts is to drop it onto the back of the wheel you pulled, otherwise it's tough to get any torque on it. This way you can kneel on the tire and it won't move. Repack your bearings and replace the inner seal while you are in there.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 03-21-2008, 08:57 PM   #8 (permalink)
1990 RRC
Thanks a ton !
Old 03-21-2008, 09:17 PM   #9 (permalink)
Rebuilding Rover
ArmyRover's Avatar
never realized that the rear rotors were such a pain in the sack. Glad my rear brakes are still in good shape
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 03-22-2008, 04:15 PM   #10 (permalink)
CLASSICRR
ROVERKRAZED's Avatar
HEY WHEN IN DOUBT I GO TO LAND ROVER MANUALS DOWNLOAD HAS DIAGRAMS AND COVERS ALL CLASSICS
ROVERKRAZED is offline   Reply With Quote
Land Rover Cross Drilled Rear rotors Disco,classic,deffender - $75 siam Land Rover Parts and Accessories 0 06-17-2007 09:01 AM
Disco Rear Brake Rotors (New) For Sale snkebyt Land Rover Parts and Accessories 0 03-11-2007 02:45 PM
Scorpion Racing Rear Bumper Install w/pics. beavis4g63t Discovery Series I 10 10-17-2006 01:38 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
