Old 09-27-2006, 12:57 PM   #1 (permalink)
Default Rebuilt Alternator?
Anyone out there had any experince with rebuilt alternators on a 4.2? Severl mechanics are saying they usually are not right for these vehicles. I found a new Merelli for $290 - not too bad I guess.
sailtom is offline   Reply With Quote
Old 09-27-2006, 01:39 PM   #2 (permalink)
ohiorover's Avatar
Default rebulit
I found a rebuilt alt from Autozone for a 92 RRC, $89.99. Surprised they had one. It was a direct fit, I installed it in the parking lot under a street light (might be a redneck) , it has worked for over two years no problem. However when I accel the headlights get brighter and the a/c fan goes into superhigh. I would assume the voltage regulator is within the alternator, but who knows with rover could be under my seat.
ohiorover is offline   Reply With Quote
Old 09-27-2006, 03:12 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
Most people I know have had back luck w/ rebuilds..... but hopefully you will have the luck ohiorover did!!
Old 09-27-2006, 04:18 PM   #4 (permalink)
ภาษาไทย
llesra's Avatar
Gallery: 16
ive had good luck with a rebuilt marelli alternator. 4 years and still good.
Arsell
My Car Domain Site
llesra is offline   Reply With Quote
Old 09-28-2006, 12:13 PM   #5 (permalink)
RageRover's Avatar
My alternator is/has started losing its charging ability. I through it on this Ocilloscope to measure my spark plug KV, or to see which cylinder has a lack of ignition power.
The machine requires a twelve volt hook up, so I just hook it to the battery. While I do this test, it looks at alternator wave patterns, and charging voltage. It is at about 13.8 volts, and the wave pattern is it little bumpy, so my alternator is gettin' worn, and from all the wheelin' I do, it does it no justice.
Might consider that Mean Green Alternator.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 09-28-2006, 04:58 PM   #6 (permalink)
gordo's Avatar
after my third rebuilt alt for my wifes D1 94, I bought a used one and tossed it in. No further probs. BTW it was from autozone and they lasted about a month each. Lifetime warranty but junk. Gordo
PS: Rover connection has some decent deals on new ones.
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
Old 09-28-2006, 06:51 PM   #7 (permalink)
Ian Matthews
p76rangie's Avatar
You can rebuild them yourself. Usually they only need bearings and brushes. A lot cheaper and you can make sure you use quality parts.
Ian
Old 09-29-2006, 06:20 AM   #8 (permalink)
Or find your self a auto electric shop that rebuilds starters and alternators, have them build yours and then you'll know it has been done right and should only cost $150 or so.
Old 09-29-2006, 10:13 PM   #9 (permalink)
my name is Todd, and I'm a rovaholic
TooSlowMonroe's Avatar
You'll never believe me...but my dealer did a great job rebuilding my altenator about eight months ago. The RR went in for other issues, and on the way, I knew something was going wrong (dealer is about 45 minutes away.) During the drive, started to hear alternator whine in the stereo (first time ever) and noticed windows and sunroof were WAY slow. Anyways, got to the dealer and the next day or two, dealer called and said the alternator had gone bad. He priced me a new one, you know how that went ($450 new, three weeks from England and all that...) and then he suggested that his guys rebuild it. I said sure, and actually stopped by to see how close it was to rebuilding the old alternator I had in my Chevy. Sure as shit, just replace the bearings, brushes and true the commutator and it was good as new. I think they also replaced some voltage regulator that was internal also.
It has worked great, and they charged me less that $100 to do it. Perhaps it was also because I think I made the dealer rent payment the month prior! LOL!
Too Slow
'05 Scion xB
'91 Mercedes 300SE
'95 Range Rover Classic LWB
'60 Ford F-250
'78 Ranger20 Sailboat
'71 Melges M-20 Scow Sailboat
TRY? There is no TRY. There is DO and DO NOT.
-yoda
TooSlowMonroe is offline   Reply With Quote
