Old 12-04-2007, 03:25 PM   #1 (permalink)
atvsmurf's Avatar
Default reciever hitch for the front...
anyone know of a supplier for a 2" receiver for the front of a '90 rrc? I have been looking at the winch setups that mount to a plate that mates with the hitch... I have seen these on xj's before...I just don't want to mount my winch on the front, then when I get stuck...pull myself deeper into the mess... this way I can pop in the the front or in the rear....
atvsmurf is offline   Reply With Quote
Old 12-04-2007, 04:32 PM   #2 (permalink)
U Haul???
carlosz is offline   Reply With Quote
Old 12-04-2007, 05:31 PM   #3 (permalink)
atvsmurf's Avatar
i did find this one Rovers North.com - Land Rover Series, Defender, Discovery and Range Rover Parts - CLASS III RECEIVER HITCH - FRONT MOUNT DISCOVERY I / RANGE ROVER CLASSIC UP TO '94 NON-SRS but that is a bit more than i was hoping to spend...
Old 12-06-2007, 03:07 PM   #4 (permalink)
Yes expensive, and too low. if you need to use it for a winch mount, it will get hung up on everything and ruin you app angle. A receiver is just a 2" square tubing. Make it yourself or have a welding/fabrication shop do it for you, you may be supprised at how little it could cost.
"Your only supposed to blow the BLOODY DOORS OFF" The Italian job 1969.
roverandom is offline   Reply With Quote
Old 12-13-2007, 10:29 PM   #5 (permalink)
repete's Avatar
remember that its 2'' SEAMLESS square tube. if you buy regular 2'' nothing will fit in it.
repete is offline   Reply With Quote
Old 12-14-2007, 04:06 AM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
They sound good in theory but tend not to be practical in reality.
Usual place to get stuck is on a hill or in a mud hole. On a hill you have to get out and get the thing out of the back. When you open the rear doors, everything falls out.
Stuck in a mud hole, you have to wade into the mud hole to get to the back to get it out. Then have to open rear door and you let the mud into the car. Then have to wade back into the mud at the front. You then have to find the reciever in the mud (most likely full of mud by now), thry and fit the winch. Ooops, drop the pin in the mud and can't find it. Then have to find the plug to connect the power, etc, etc.
Old 12-14-2007, 05:52 AM   #7 (permalink)
TerryS's Avatar
You will loose forward traction well before you get to the worse part of most show stopping situations, so generally, the best way out is back the way you came. A removable winch is better used on the back end than the front end. They can make a great land plow on steep ascents, so don't put it on till you need it.
Old 12-14-2007, 07:50 AM   #8 (permalink)
Rocky Mountain High
Funrover's Avatar
Ironic you bring this up about XJ's.... What I am doing to the fiances Jeep for a front recovery etc is buying a hitch from the scrap steel place(where you pay so many cents per pound) and Building all the brackets etc ... that way I have a true 2" reciever and I will make a front bumper with it so as not to lose clearence! Just a thought!! If you buy one that is bolt on it really kills approach angle... Also of you do mud a lot when you get stuck and want out the reciever will be full of crap you have to clean out before you even get a winch in there!! I understand wanting 1 winch for front and rear though!! But call arounf to junk/scrap yards for hitches.. Then build a bumper and that is part of it!
No power to front wheels Sign Guy Range Rover Classic 3 12-25-2006 04:42 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
Oh man...(flame suit is on) 02disco2 The Lounge 9 03-27-2006 11:51 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
front end... click click click + other stuff johnjcoyle Discovery Series I 8 01-20-2006 01:00 PM
