Old 10-05-2005, 02:19 AM   #1 (permalink)
LRO Founder
Serg's Avatar
Default Reducing turning radius
My understanding is that there is a way to reduce the turning radius on a RRC... Of the 3 RRC's that I had had, including one with 265's on it, my current one has the worst turning radius by far.. I was told there is a way to reduce the turning radius via some adjustments... anyone?
Current Vehicles:
2003 BMW 540iT M Sport
2005 BMW R1200GS
2004 Element Skateboard (Indy trucks, Bones Swiss, etc...)
Past LR's:
1995 Range Rover LWB Classic
1997 Discovery XD
1995 Range Rover LWB Classic 4.0
Serg is offline   Reply With Quote
Old 10-05-2005, 04:47 AM   #2 (permalink)
there are some 'bump stops'/nuts, on the swivel housings that adjust in/out. Maybe someone had larger tyres that 265's on an adjusted these out ?? I run a Grizzly Claw and the offsets on my rims just wont cope and they rub on the C bars.....
champ69 is offline   Reply With Quote
Old 10-05-2005, 01:41 PM   #3 (permalink)
Geoffrey F Miller's Avatar
The swivel hubs each have an adjustable lock nut, which limits the amount to which the hubs can turn.
These should be adjusted, starting with the preset described in the manual. Then they should be fine-tuned so as to limit full lock at a point when the PAS pump and box remain silent. If a greater degree of full lock is allowed, so that the PAS pump and box are working, damage to the PAS system will occur.
In other words, set the steering as per the manual and don't try to be clever - it'll cost bucks if you do!
Geoffrey
1985 4-door Range Rover Classic
Geoffrey F Miller is offline   Reply With Quote
