ChamplianRover
Like a true weekend mechanic, I removed my distributor before marking its position in order to replace the front cover gasket.
Well, the gasket is done and I am putting my 95 LWB back together. Can anyone provide a step by step process to line everything back up so the timing is at least close enough to start the rig and get it to a mechanic who has a timing gun in order to fine tune it? Thanks, ChamplainRover |
Find your timing mark on the crank pulley and line it up with the indicator, remove #1 spark plug and verify piston is at top dead center (TDC) reinstall spark plug and wire. Find #1 wire on distributor cap, and mark distributor base where #1 is. Install distributor with rotor pointing at #1 mark. Tighten down distributor and reinstall cap. If it doesn't start, Bring #1 piston back up according to crank mark. Check position of rotor, and remove and reinstall distributor exactly 180 degrees from 1st position. Set timing with light.
ChamplianRover
Bwana,
I did, and I thank you for the help. I put the distributor back in and it didn't start, so I pulled it out, turned the gear 180 degrees, put it back in, then was able to start it. Took it to a garage and got it timed, and she's running great! Thanks again for your initial response and for following up. ChamplainRover |
| Thread Tools | |
| Display Modes | |
| Mallory Distributor, Coil, Magnecors, ect. | Paul Grant | Land Rover Parts and Accessories | 0 | 11-15-2007 05:00 PM |
| 93 RRC distributor salvagleable? | pie4foou | Land Rover Parts and Accessories | 5 | 11-15-2007 03:38 PM |
| Dead Distributor!????? | Disco 1 | Discovery Series I | 2 | 10-16-2006 09:31 AM |
| buick distributor | cobb ridge | Range Rover Classic | 2 | 09-16-2006 06:22 AM |
| Distributor | tlry00 | Range Rover Classic | 5 | 09-21-2004 07:09 AM |
