» Sponsors
» Sponsors
Old 10-19-2009, 08:04 PM   #1 (permalink)
Default Removing clutch from fan?
I was going to replace the water pump on the '95 RRC thins week , since I noticed it was leaking from the weep hole last week....
Today the pump siezed completely, so my timetable got moved up a little. It all came apart with no problem, I used a large adjustable wrench on the waterpump nut for the fan and it came right off (and I thought that was gonna be the tough part) The old pump didn't look bad, no erosion of the impeller , and it was nice and clean inside, but it was completely siezed and I couldn't turn it even after I got it off the truck.
I also picked up a new fan clutch , and here the problems began....the clutch is connected to the fan itself by 4 5mm hex bolts, and I couldn't get them off. I PB Blastered the heck out of them, and tapped the them with a hammer, all the tricks....I ended up snapping two hex wrenches, and I couldn't break them loose. I ended up putting the original clutch back on....
Is there a trick to getting the fan off the clutch? I cannot get this thing off, and I can't figure out why.
ranger1968 is offline   Reply With Quote
Old 10-19-2009, 10:52 PM   #2 (permalink)
OldnDirty's Avatar
Funny, I took two of those apart today. They came right apart with a 13mm wrench. Then I just knocked the fan off the clutch. Try using an impact wrench.
Lord grant me the serenity to accept the people I cannot shoot
The courage to shoot the ones I can
And the wisdom to know the difference
-Shea's serenity prayer
OldnDirty is offline   Reply With Quote
Old 10-20-2009, 05:40 AM   #3 (permalink)
Thanks, I'll give it a shot with the impact. The pump siezed in a friend's driveway, so I did not have any air available while I did the r &r on the pump, but she's home now, so I can put the impact on it. I know I have some hex drives somewhere....
Clutch Problem IMOGEN Discovery Series II 2 09-04-2009 01:32 PM
Removing the fan clutch off my 94 RR Sam Missaghi Range Rover Classic 2 08-07-2009 09:05 AM
Clutch help dsfloyd Series Land Rovers 2 05-17-2009 09:12 AM
water pump - fan clutch ?'s voneyeball Range Rover Classic 9 09-21-2008 12:26 AM
clutch 1965 series IIA captcory Series Land Rovers 3 05-14-2006 01:40 PM
