» Sponsors
» Sponsors
Old 10-24-2009, 12:09 PM   #1 (permalink)
Default Removing the fan
I am trying to replace the water pump on my early production 92 RR and I can't seem to remove the fan. There is a large nut behind the fan towards the engine block and I assume that's what I need to remove, however, when I put a wrench to it, it just turns freely with the water pump. What am I missing here? Is there some way to lock it down? I will post a few pictures.
Thanks
mtoenjes is offline   Reply With Quote
Old 10-24-2009, 12:49 PM   #2 (permalink)
It is reversed threaded... righty loosey lefty tighty.
I just put a big C wrench on it & whack it with a hammer.
Kevin
88 RRC "Audrey"
Old 10-24-2009, 12:59 PM   #3 (permalink)
rover tech's Avatar
Gallery: 3
Land Rover has a tool to hold the pump pulley while you turn the nut.Try to wedge a long screw driver between one of the bolt heads and the fan boss. I that doesn't work you can put a wrench on the nut and postion it to where you can get a good clean shot at the end of the wrench and smack it with a quick sharp blow in the proper direction to break free the nut. Because you are replacing the pump you can take a hammer and give the wrench a good rap downward and slightly in direction of removal this usually works but there are some that are a real pain. good luck
rover tech is offline   Reply With Quote
Old 10-24-2009, 12:59 PM   #4 (permalink)
It spins freely in both directions. There has to be a way to stop the pump from turning.
Edit* A tool to hold the pulley would help. I will try the other suggestions. Are you certain it is reverse threaded?
While we are looking under my hood, I was wondering if it would be okay to leave the AC belt off? The AC isn't working and the tensioner tends to squeek from time to time.
Old 10-24-2009, 01:32 PM   #5 (permalink)
I take a vise grip and clamp it onto one of the pulleys preventing any movement in the direction I have to hit the wrench to loosen the nut. Works every time and it's a hell of a lot cheaper than a special tool.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 10-24-2009, 01:33 PM   #6 (permalink)
And Kevin is correct about the direction. From serpentine configurations onward they went the other way.
Paul Grant
paulgrant@mac.com
203-770-1699
Old 10-24-2009, 01:45 PM   #7 (permalink)
That wont bend the pulley?
Old 10-24-2009, 03:56 PM   #8 (permalink)
You have to use some care but I haven't had a problem with the hundreds of fans I removed.
Paul Grant
paulgrant@mac.com
203-770-1699
Old 10-24-2009, 04:26 PM   #9 (permalink)
Thanks for all the input. I managed to remove it using vice grips.
Removing SAI ealex Discovery Series II 14 08-05-2009 12:56 PM
Removing speedo cable DiscoTom Discovery Series I 13 06-04-2008 08:20 PM
removing cats rov'n Discovery Series I 14 09-05-2005 03:17 PM
removing sidesteps info please Phlawed Accessories 6 08-28-2005 10:36 PM
Removing Viscous Fan hugodiscoII Discovery Series II 4 06-18-2005 12:30 PM
