Old 03-31-2006, 02:02 PM   #1 (permalink)
ryans ROVER
ryanc8514's Avatar
Default rovertym 2" body lift
i have been considering getting a 2" body lift by rovertym...i recently found out that the kit comes with 10 spacers for the body, radiator, transfer case, seat belt tensioners, and a coupler for steering shaft...has anybody installed this themselves? what was the difficulty? any idea how much a shop would charge to install this?
http://www.roverunited.com/tech/rove...-body-lift.htm
ryan mura
1994 range rover county lwb
-BIG BLUE 3" coil spring suspension lift
-Procomp ES3000 shocks
-custom snorkel
-glasspack exhaust system
-285/75/R16 all terrain tires
-old school CB radio from the 80s-cobra
-speakers loud enough to set off car alarms
-LR3 side air vent
ryanc8514 is offline   Reply With Quote
Old 03-31-2006, 02:06 PM   #2 (permalink)
smileyq's Avatar
I haven't installed a body lift on a rover but did on a jeep and wasn't every happy with it. In my experience body lifts simply aren't a good thing much over 2" to gain a little tire clearance. Anything highter than that leads some some issues down the road if your not careful. Just my .02
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
Old 04-04-2006, 04:57 PM   #3 (permalink)
4x4 Adventure Gear
John C's Avatar
I did the RTE install on a friends Rangie, not very difficult. Hardest part was getting the rusted bolts out. We did bring the steering shaft to a welder to weld an extensionon it (included in kit).
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 04-04-2006, 05:10 PM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
For a 2 inch lift you should not have to extend the steering shaft. The lift itself is very easy, you can do it in half a day. It is the lining up the front and rear bumpers and other realignment that takes a little time. Fitting the kits by relatively unskilled people should not be an issue.
Ian
Old 04-04-2006, 06:58 PM   #5 (permalink)
4x4 Adventure Gear
John C's Avatar
Ian
Ian, the kit from RTE comes with a short extension for the steering shaft. If you loosened the shaft ends and pulled out the shafts from the coupler you cannot insert the bolt back in (is this confusing or what)..... I have a spare shaft laying around, I'll try and post pics tomorrow ...
John C
Old 04-04-2006, 07:50 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
John, I have a 2 inch body lift and did not need to play around with the shaft. If you loosen off all 4 bolts, there is enough movement to allow things to fit properly.
Ian
