ryans ROVER
i have been considering getting a 2" body lift by rovertym...i recently found out that the kit comes with 10 spacers for the body, radiator, transfer case, seat belt tensioners, and a coupler for steering shaft...has anybody installed this themselves? what was the difficulty? any idea how much a shop would charge to install this?
http://www.roverunited.com/tech/rove...-body-lift.htm
ryan mura 1994 range rover county lwb -BIG BLUE 3" coil spring suspension lift -Procomp ES3000 shocks -custom snorkel -glasspack exhaust system -285/75/R16 all terrain tires -old school CB radio from the 80s-cobra -speakers loud enough to set off car alarms -LR3 side air vent |
I haven't installed a body lift on a rover but did on a jeep and wasn't every happy with it. In my experience body lifts simply aren't a good thing much over 2" to gain a little tire clearance. Anything highter than that leads some some issues down the road if your not careful. Just my .02
"Good saddles ain't cheap, and cheap saddles ain't good." |
#3 (permalink) | |
4x4 Adventure Gear
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
Ian Matthews
For a 2 inch lift you should not have to extend the steering shaft. The lift itself is very easy, you can do it in half a day. It is the lining up the front and rear bumpers and other realignment that takes a little time. Fitting the kits by relatively unskilled people should not be an issue.
Ian |
#5 (permalink) | |
4x4 Adventure Gear
Ian Matthews
John, I have a 2 inch body lift and did not need to play around with the shaft. If you loosen off all 4 bolts, there is enough movement to allow things to fit properly.
Ian |
