» Sponsors
» Sponsors
Old 10-17-2009, 03:26 PM   #1 (permalink)
Default RRC Mechanic
Ok so since I was hoping to get all the stuff I needed done on my own without a lift my rover threw me off in the direction where I need a local mechanic or just a LR enthusiast with a lift. Does anyone happen to be or know someone who knows older LRs such as D1s or RRCs in the Middle Tennessee Area ( I don't want to head to Memphis or Knoxville) who has a lift or just a basic knowledge of older LRs. The reason I need a lift is (I don't have a garage or a jack and I was hoping not to have to buy mechanic tools) my RRC has a tube that goes from the filler neck to the top of the tank and according to Paul Grant and hisr RRC technician in order to replace that part I need to drop the tank and since I'm new to the LR world and not only that but the auto repair world I need someone who understands LRs to give me a hand
Thanks for putting up with all of my post that lead to dead ends
1995 RRC LWB Beluga Black 175K and still trucking
http://www.cardomain.com/ride/3384937
Davisch75 is offline   Reply With Quote
Old 10-18-2009, 03:25 PM   #2 (permalink)
Also, does anyone know how to drop the fuel tank on a 95 RRC? I've heard it is quite difficult and I would like to know what I'm getting myself into
Old 10-18-2009, 05:19 PM   #3 (permalink)
This is from RAVE. I hope this helps!
CAUTION: Before disconnecting any part
of fuel system, it is imperative that all dust,
dirt and debris is removed from around
components to prevent ingress of foreign matter
into fuel system.
Remove
1. Depressurise fuel system. Disconnect battery
negative lead.
2. Syphon fuel tank into a suitable container that
can be sealed afterwards.
ENSURE TANK IS DRAINED COMPLETELY.
(refer to Warning concerning fuel vapour and
spillage at start of procedure).
3. Remove carpet loadspace floor and tailgate.
4. Fold back sound insulation to reveal access
panel.
5. Remove access panel.
6. Disconnect electrical multi-plug.
7. Disconnect two fuel line unions from fuel pump.
8. Working underneath vehicle mark location of
anti-roll [sway] bar straps.
9. Remove rear anti-roll [sway] bar straps, and
allow bar to swing down clear of tank.
10. Remove tank filler and vent hoses at fuel tank.
11. Remove nut and bolt securing right hand side
fuel tank strap.
12. Disconnect evaporative control pipe at green
end of ’speedfit’ connector.
NOTE: To disconnect ’speedfit’ connector,
insert forked end of LRT-19-002 into slots
of connector see illustration. Press down
on collet and simultaneously pull pipe from
connector.13. Remove back two bolts and nut plates securing
fuel tank cradle.
14. Remove front nuts, bolts and washers. Remove
fuel tank cradle.
15. With assistance, tilt right hand side of tank
upwards and manoeuvre tank through chassis to
remove.
Kevin
95 RRC wifes
92 RRC mine
72 Series 3
Morgan + 8 (with a 4.6 racing engine with 4 Webers)
90 jetta with 300K
kevin-ct is online now   Reply With Quote
Newb 2.25 diesel owner looking for a mechanic or engine rebuild kit Uhhh...Clem! Series Land Rovers 3 06-21-2009 03:48 PM
Mechanic needed in San Francisco sesherrick General Land Rover Discussion 0 02-16-2009 10:59 AM
So. Arizona Mechanic Recommendation dcwhybrew General Land Rover Discussion 1 01-08-2009 10:37 PM
Bad Mechanic CurvyRover Range Rover Classic 4 01-17-2006 05:03 PM
mechanic question CurvyRover Range Rover Classic 5 01-08-2006 06:17 PM
