Old 06-01-2006, 02:50 PM   #1 (permalink)
Default RTE Body Lift Problems
I am in the process of installing my RTE body lift on '90 RRC. I am trying to get the steering shaft out for the weld on sleeve. The shaft seems to be completely "bottomed out" in the collar closest to the cab and almost bottomed out in the collar on the u-joint between steer box and cab AND there's not much room for it to move within the collar right at the steer box. It's almost like the shaft is long enough without the lengthening collar. I am wondering if the shaft will get too long when I weld the RTE lengthening collar to the shaft. Has anyone been able to install the 2" body lift without the shaft "lengthener".
Thanks for bearing with me guys.
J.B.
emmodg is offline   Reply With Quote
Old 06-01-2006, 03:00 PM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
I have a 2 inch body lift with the standard steering shaft. Should not need to extend it for a 2 inch lift, but you do need to make sure they can move on the splines before starting the lift.
Ian
Old 06-01-2006, 06:35 PM   #3 (permalink)
Otherwise known as STEVE
I wouldn't weld on the steering shaft anyway- bad idea.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
