Old 04-09-2008, 05:52 PM   #1 (permalink)
TJ Nasty!
Jahmusac's Avatar
Default Seats wont work with door closed!! RRC LWB
My 95 classic LWB seats no longer work with the door closed. When I open the door and the cabin light comes on the drivers side seat and side view mirrors start working. they were working fine until they stopped working.
Any insight people?? Help a guy out!! LOLOL!!
!!!!Thanks!!!!
Jahmusac is offline   Reply With Quote
Old 04-10-2008, 08:40 AM   #2 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
Grounding issue?? ECU??
Support the Troops = Support the Mission
Don't say it if you don't mean it.
1994 RRC LWB, 82k miles, 4.2, Cornish Cream/Lightstone Interior, spring converted.
BullDogSix is offline   Reply With Quote
Old 04-11-2008, 02:35 PM   #3 (permalink)
at some point it will break . . . and I will ATTEMPT to fix it!!
Dr Lobster's Avatar
I'm gonna take a shot and say it may be a relay BECAUSE the seats are set up to be adjusted with the door open to adjust between the two preset memories settings, so when the door closes, a relay would switch to disable the seats until the vehicle was on or running. But I'm not really sure if there is even a relay for this purpose.
So nothing happens at all, even while running??? I know mine won't work with the door closed and the vehicle is off, but as soon as it's running, or the key is in the on position, everything works.
With as many flukes with the electrical system, I need to ask: Is there any reason why you can't adjust the seat while the door is open and live with the "No Power Seats While Door Closed" dilemma???
1991 Mitsubishi Galant VR4 717/2000
Arias Pistons/Eagle Rods, '94 Talon Tranny
-Fun as hell, always broken
1986 Chevy K20 AKA White Lightning 350, 4 Speed, 3" Lift, 32" Maxxis Buckshot Mudders
-Never broken, always out of gas
1995 Range Rover CountyLWB AKA Darth Vader,K&N air filter, coil spring conversion, Maxxis Bighorn Mudders
-The ULTIMATE TAOS VEHICLE
Dr Lobster is offline   Reply With Quote
Old 04-11-2008, 10:09 PM   #4 (permalink)
TJ Nasty!
Jahmusac's Avatar
whats really lame is the passenger side doesnt work at all.i hear lots of complaining, and when my girl drives im leaning back in the seat to far.
Anyways.....The drivers side seat and side view mirrors work when the drivers side door opens but not until the cabin light comes on as well.
itll probably be easier to take it to some kind of mechanic and let them figure it out.
thanks!!
Old 04-12-2008, 08:07 AM   #5 (permalink)
BullDogSix's Avatar
Gallery: 2
It's been my experience that unknown electrical problems + mechanic = Large amounts of $$$ leaving your wallet. I would spend a little time investigating it further...I know its frustrating...I'd just hate to see your experience soured even further with a costly mechanics bill and possibly still have a problem.
Old 04-29-2008, 08:17 PM   #6 (permalink)
Default this might help your seating position
check your earth connections, if you spray water over them or when it rains, and the seats function properly, then you could have a grounding (earth) problem.
imajica is offline   Reply With Quote
Old 04-29-2008, 09:58 PM   #7 (permalink)
repete's Avatar
If the 95 is set up like my 93, do a ecm test. if your drivers control has the green button & the #1 &#2 buttons, make sure nothings in the way of the seats, turn the key to the on position push the green button 5 times then 2-1-1-2. the seats and mirrors should move in all planes of opperation.
repete is offline   Reply With Quote
Old 05-06-2008, 04:04 PM   #8 (permalink)
I had the exact same problem on my RRC - turned out to be two fuses under the passenger seat. You can access most of the fuses under the seats from the back, but there are a couple that you may have to take all the plastic panels off the seat base to gain access to. Good luck
nasheduk is offline   Reply With Quote
Prison vs. Work Funrover The Lounge 3 03-17-2008 01:51 PM
F/S Range Rover Classic Grey Manual Seats Paul Grant Land Rover Parts and Accessories 4 12-12-2007 02:12 PM
Prison Vs. Work rmuller The Lounge 11 04-11-2007 08:02 AM
1994 LR Disco Seats taskforce121 Land Rover Parts and Accessories 0 07-15-2006 08:46 AM
Excuses To Miss Work kellijo The Lounge 3 04-26-2006 10:33 AM
