Old 03-22-2008, 07:30 PM   #1 (permalink)
Default Settle A Bet
A friend of mines 2nd car has developed a bad rod knock. It is Chrysler Concorde with a 3.3l v6. He says that if he pulls that rod and piston out that the motor will be fine. He says worst case he would need to pull 2 rods and pistons one on each side. He is also going to unplug the injector/s and remove the push rods from the area with out the piston/s.
I bet a $100.00 that it wont last longer then a month.
skippermccoy is offline   Reply With Quote
Old 03-23-2008, 10:47 AM   #2 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
That's about the stupidest thing I have ever heard of, removing rods and pistons to get rid of knock. Crap, how hard is it to put bearings in, especially when you are already unbolting the rods?
Jim Hall
obstacle.” Michael
Old 03-23-2008, 11:16 AM   #3 (permalink)
It is pretty much a car he doesnt need. It has been knocking for a good month if not more so odds are the crank is shot and would need to be ground. I have been searching for more info on it. There is a company that does that to vw motors. They turn them into 2 cylinders for planes. You can get it with the full block or a block cut down to just the 2 cylinders. They use the air cooled motors.
Old 03-23-2008, 12:03 PM   #4 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
If some bearings are gone, the rest are on their way. If you remove rods and pistons, the crank will be unbalanced, hastening the demise of the crank bearings. You will have to weld shut the oil holes from the removed rod(s) or the oil pressure will be even worse. Still the stupidest thing I have ever heard of.
Jim Hall
obstacle.” Michael
Old 03-23-2008, 12:19 PM   #5 (permalink)
frickjp's Avatar
Balance is the least of said idiots worries. It won't last a day. Rod bearings don't fail for the Hell of it, they fail due to lack of oil pressure. Without a rod on that journal, the engine will have a 1/4" pressure fed oil hole in the crank, and what's left of the POS will have no oil pressure whatsoever.
frickjp is offline   Reply With Quote
Old 03-23-2008, 01:34 PM   #6 (permalink)
So it looks like I will have an extra hundred.
Old 03-23-2008, 02:33 PM   #7 (permalink)
Well he did it. It runs surprisingly well. No nosie no odd vibration not much of a power loss. His oil pressrue on the aftermarket gauge is actually reading around 30-35. I still have faith it will fail with in the month. He said it is only a 20 min job to pull the oil pan in that car. He also said the crank is toast
March 28th, Daily News OkieRover The Lounge 5 03-29-2007 07:03 PM
Should I settle for Land Rover DII Leaks? akalana Discovery Series II 6 08-21-2006 09:24 AM
