Links
Old 04-27-2008, 06:25 AM   #1 (permalink)
RRC Owner in training
BullDogSix's Avatar
Gallery: 2
Default Shock Question...
My 1994 LWB's air suspension was converted to springs sometime time in the past, previous to when I got it. I'm slowly going through things and on the list is new shocks. So my question is...for new shocks which do I get...for air suspension or without air suspension. I only ask because I noticed my front shocks are not up through the center of the coil spring as I've seen on others. I'm assuming I would need to buy shocks for air suspension?...correct. Is there a kit or parts to buy to put it back through the coil? Is that better than what I have now?
Solution or Problem...Which are you?
1994 RRC LWB, 82k miles, 4.2, Cornish Cream/Lightstone Interior, spring converted.
BullDogSix is offline   Reply With Quote
Old 04-29-2008, 12:10 PM   #2 (permalink)
I have a 1995 SWB and I have the same exact question. Is through the coil better than out of it like on mine?
FoCoRRC is offline   Reply With Quote
Old 04-30-2008, 06:50 AM   #3 (permalink)
You can use the EAS shocks when converted to springs by simply not removing the EAS-style shock mounts when installing the springs. Those are what is different.
'95 RRC LWB, '05 Suburban Z71 (not stock), '94 F350 (very ugly), '62 International 404 tractor (red & white) & many other project cars in the past!
57loboy is offline   Reply With Quote
ANOTHER broken OME shock! AZROVER General Land Rover Discussion 16 04-16-2008 06:31 AM
HOW TO: Lifting a rover! Funrover Tech & DIY 0 01-06-2008 08:27 PM
MAF sensor housing question tcpfl Discovery Series II 2 11-12-2007 04:49 PM
Shock question Kevin88RRC Range Rover Classic 1 03-24-2007 08:51 AM
Shock Absorber Mounts P38 Googsy Range Rover P38, Mk III and Range Rover Sport 0 11-02-2005 01:02 PM
