i also have this problem...i got an aftermarket cd player installed and i began to get engine noise and the speakers would cut in and out..i found out its because the way the cd was wired was using both the cd player power and the factory amplifier power...a possibility is that your amp could be going bad...there is so much wiring involved with the stereo i think that the wires get loose. the radio itself could also be going bad giving a bad signal out to the speakers
ryan mura
1994 range rover county lwb
-BIG BLUE 3" coil spring suspension lift
-Procomp ES3000 shocks
-custom snorkel
-glasspack exhaust system
-285/75/R16 all terrain tires
-old school CB radio from the 80s-cobra
-speakers loud enough to set off car alarms
-LR3 side air vent
