Old 07-18-2006, 06:53 PM   #1 (permalink)
Default speedometer
upon driving my 1990 rr the speedo started going crazy and finnaly peged pointing straight down any ideas on what might have happened or how to fix this..
Lucasfree is offline   Reply With Quote
Old 07-18-2006, 07:25 PM   #2 (permalink)
RageRover's Avatar
Sounds like the speedo sensor, had a bad connection and then finally dropped off. You can check the sensor on the back of your Transfer case, see if it is connected good.
Also the speedo needle might have an issue with it. I am not too sure.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
