» Featured Product
» Sponsors
» Sponsors
LandRoversOnly.com is the premier Landrover forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 07-20-2009, 06:23 PM   #1 (permalink)
Default Speedometer & Check Engine Light
OK, so my speedometer has been acting little weird. Just purchased 95 RRC few months ago with 165K miles. Everything runs good but the speedometer didnt register a couple of times while on the freeway. Went to zero and then popped back to normal in a matter of a second. Today, was sitting idle in traffic and the speedometer didnt work when I went from zero to about 70 mph. Stayed at zero for about a good mile and then the check engine light came on. Then the speedometer starting working again. Now the check engine light is on and the car feels normal. If there any connection between the two??
Thanks!
Urbanrover is offline   Reply With Quote
Old 07-21-2009, 04:54 AM   #2 (permalink)
If I recall correctly, the VSS supplies info to both the speedo and ECM so if that went bad, it could affect the speedo and trip the CEL....
'95 RRC LWB
57loboy is offline   Reply With Quote
Old 07-21-2009, 03:15 PM   #3 (permalink)
Default code 68
Thanks, I looked up the code and it read 68, Road Speed Sensor. I'm sure it triggered the Check Engine Light. The speedometer working again, so i will attempt to reset the Check engine light and hopefully it will not appear again, unless the speedo goes out again!!
Thanks!
Old 07-21-2009, 04:20 PM   #4 (permalink)
SeattleRRC's Avatar
Gallery: 44
My speedo did the same thing off and on for several weeks about a year ago- I didn't do anything about it and it 'went away'. =)
'94 D90 ST 124K mi
'90 RRC SWB 236K mi
'75 Series III 88" 63K mi - SOLD
SeattleRRC is offline   Reply With Quote
Old 07-21-2009, 04:42 PM   #5 (permalink)
I hope to have the same luck!!
Old 04-28-2010, 05:23 PM   #6 (permalink)
Did you ever get your speedo fixed?.. Mine did the same thing and has been dead for about a year now..I think Its the VSS but really expencive to be wrong
johnsbrat is offline   Reply With Quote
Help! Check Engine Light Comes On & Engine Always Loses Power After Hitting Pot Hole! Jungle Man Discovery Series II 7 09-10-2009 07:50 AM
P0125 code thrown but no check engine light. pavel Discovery Series I 3 06-17-2009 05:39 PM
Check Engine Light Blazer7 Freelander / LR2 0 01-25-2009 08:32 PM
97 Disco- check Engine Light on and rough running - loss of power lajilana Discovery Series I 3 08-06-2006 08:03 AM
Check Engine light mossrock98 Discovery Series I 2 09-03-2004 02:03 PM
SEO by vBSEO 3.3.2
