Old 05-01-2005, 08:55 AM   #1 (permalink)
Default Sprung a leak!
My 1990 RR 3.9 EFI V8 has sprung a leak!
It appears to be eminating from just behind the distributor and is dripping down the side of the engine, making the most hideous stench when hot.
I suspect the left gasket has given up the ghost (left hand from sitting inside the vehicle) but it may not have. A bit of white smoke from the exhaust intermittently. Nothing lighting up on the dash. There seems to be NO oil when checking the dipstick, but the wouldn't I get a light? Will put some more in, just to be safe. Want to rebuild anyway. What could be wrong?
L
Not driving it anywhere until it's fixed...lol
Psychobiker is offline   Reply With Quote
Old 05-01-2005, 04:04 PM   #2 (permalink)
13 views and no response....
Old 05-01-2005, 05:56 PM   #3 (permalink)
come on...TTT
Old 05-02-2005, 02:42 AM   #4 (permalink)
Old 05-02-2005, 05:05 AM   #5 (permalink)
4x4 Adventure Gear
John C's Avatar
L
I'm just guessing but it could be the valley pan gasket.
When did you check the oil, when the engine was hot? Try checking it early in the morning before starting the engine.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 05-02-2005, 06:05 AM   #6 (permalink)
Wheeler
SCSL's Avatar
If you're driving a '90 that just sprung an oil leek you are a lucky man !!
Old 05-02-2005, 06:39 AM   #7 (permalink)
OkieRover's Avatar
Gallery: 2
Just behind the distributor is two heater supply hoses. Are you sure one of them hasn't failed?
http://www.okierover.com/heatersupplyhoses.htm
No oil on the dipstick???? Ummmmm that's not good. Put some in.
I punch my clown daily.
Old 05-02-2005, 03:16 PM   #8 (permalink)
lol, this could be good. I was getting a bit of white smoke yesterday, but I'd just powerhosed the engine and maybe that got in somewhere?!
I'll rip them all off - what happens if they do? All allfcuking everywhere?
Lol - it's staying where it is until fixed, so on the numerous occasions I've checked, the oil is not in there at all, just picked some up and will put it in tomorrow.
I'm 16...this is crazy, lol
Old 05-03-2005, 06:20 AM   #9 (permalink)
OkieRover's Avatar
Gallery: 2
One more time with feeling...
I didn't get "RIP THEM ALL OFF" what are you going to rip off? And I'll try to tell you what happens.
Old 05-03-2005, 07:15 AM   #10 (permalink)
troverman's Avatar
It is probably the headgasket--check the coolant. Be careful, it may be overpressurized by the engine compression. If it is pressurized, and you hear bubbling sounds (check when the engine is warm) than it is the gasket, at worse you have a cracked block. Blowing white smoke out when the engine is warm means the engine is burning coolant.
However, maybe all you have is a leak. Check those metal pipes which run over the valve cover. Make sure the cap is on tight, and the hoses are on tight.
Current:
2005 Land Rover LR3 V8 SE
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rover:
1995 Range Rover 4.0SE
Old 05-03-2005, 07:50 AM   #11 (permalink)
4x4 Adventure Gear
John C's Avatar
Hey Trover,
I'm heading up to Manchester next wed and thur, are you close by?
John C
