I am going to be getting a new steering damper and alignment within the next few weeks. My 95' LWB still has the EAS - functioning fine. I was wondering if I should replace anything else ( shocks) while I get the damper installed? I still have the facotry shocks and was thinking of replacing them with Bilsteins. Didn't want to mess with the EAS until I have too, then will most likely convert to springs.
LRO Founder
I have Bilsteins on my '95 LWB and they work great. If the shocks are shot, replace em.. if they are fine, leave em alone. It will be cheaper to do it when you do the EAS, otherwise you have to pay extra labor now and then again when you do the EAS conversion.
Serg
Current Vehicles: 2003 BMW 540iT M Sport 2005 BMW R1200GS 2004 Element Skateboard (Indy trucks, Bones Swiss, etc...) Past LR's: 1995 Range Rover LWB Classic 1995 Range Rover LWB Classic 1997 Discovery XD 1995 Range Rover LWB Classic 1995 Range Rover LWB Classic 4.0 |
If you you plan on doing any offroading, you might want to think about a relocating kit that moves it to the front like a defender. http://www.eastcoastrover.com/offroadequip.html has one and I'm sure there are others.
Kevin 88 RRC "Audrey" |
Why you are replacing the steering damper on your 95? What are the symptoms you get or do you visually see the shock leaking?
I have 95 LWB and I am thinking of replacing mine because it is loose over a bump and steers all over when driving. |
Adrian... you may want to check swivel preload first. The new dampener may just mask the problem. Check out this article http://www.landroverclub.net//Club/H...obble_cure.htm
#6 (permalink) | |
After I replaced my shocks that problem went away for me.
#9 (permalink) | |
#11 (permalink) |
well, my tie rod ends are practically new but the other hand, steering damper is rusted thru and shot.
I went to Atlantic British and price was 99.95. So I went to Rovers North and price was 85.00. I have ordered thru Rovers North. Will see what happens after the replacement. Is it really hard to replace the steering damper? Do I need alignment after that? ![]() |
#12 (permalink) | |
-Coach |
#15 (permalink) |
Steering Stabilizer:
The OEM Range Rover steering stabilizer (damper) costs $92 (NRC6474). Bilstein part number B36-0245 can be obtained for about $65. Another option is the Rancho 5403, 5405, or 5550. I found the latter at ExpressAutoparts.com for $28. ============ This came from http://www.rangerovers.net/rrpartsv.htm I ALWAYS check this site first. ============ Yea, I've had my share of wobby steering after hitting bump. Most recent for my 1991 with 174K miles was panhard rod ends. Tie rod end once. Once I had two different tires on Michelin (very old style & newer style) caused the problem. Get under steering components (engine off) and have someone like my 8 yrs old son turn steering wheel back/forth. Look for shifting geometry (parts not moving right). Could be preload on swivel housing or worn steering box (although back lash is adjustable). Another way is to check is put bottle jack under axel. Raise one wheel off ground at a time. Grab tire with both hands and try latteral push/pull. You'll feel how loose tie rod ends and other steering links may be. Problem is you can't see what is the issue. Then tire iron under wheel, lift up. There should be smooth movement of the tire, no sudden shifting upper or lower. Usually this checks ball joint but you probably have swivel housing (ajust preload). |
| Thread Tools | |
| Display Modes | |
