Old 03-08-2005, 05:37 AM   #16 (permalink)
Default Rovers.net info
Thanks for the info Glencof. I find some of the pricing on the rovers.net is outdated and no longer accurate. I have checked numerous sites for the exact models and found that OEM Woodhand damper is $77.00, OME(Old Man Emu) is $65.00 and Bilstein is $85.00 average. Maybe sometimes it might be cheaper at ebay or someone can find better pricing than above average.
AdrianL is offline   Reply With Quote
Old 03-11-2005, 05:29 AM   #17 (permalink)
Default Replaced with Bilstein and perfect!!
I replaced my steering damper last night with Bilstein from Rovers North.
Took me half hour to replace.
After replacing, took it for a test drive and boy, what a difference. Steering is tight, no more bouncing and vibrating over bumps.
The original damper was totally shot. Case was ALL rusted out, inner piston lost all the gas/fluid and it was freely moving.
I highly recommend Bilstein as a replacement over OEM.
Old 03-25-2005, 06:20 PM   #18 (permalink)
azpaquin's Avatar
Default steering dampner.. that was it.. lucky..
Lucky lucky.. could have been the panhards, tie rods, trailing arms.. not to forget all those little bushings.
When the front end loosens up again.. panhard
I did the steering dampner a couple of years ago and the front end loosened up in other areas.
Get ready this is only the beginning for ya.
azpaquin is offline   Reply With Quote
Old 03-28-2005, 04:45 AM   #19 (permalink)
Default Looks good for now
PO maintained the vehicle pretty well and my mechanic checked to see if I needed any front sttering components and it looks good so far. Also, my car is covered under warranty, so replacement won't be an issue.
Old 04-04-2005, 07:51 PM   #20 (permalink)
Default OME Damper w/ shipping $78 - Atlantic British
Just put on an Old Man Emu damper (15 minutes of labor) and got an alignment done. Considerable improvement - no more steering wheel vibrations over bumps at high speeds. The OME was recommended to me over the Bilstein. So far, so good.....
NJRover is offline   Reply With Quote
Old 04-18-2006, 07:12 AM   #21 (permalink)
ryans ROVER
ryanc8514's Avatar
im considering getting an OME steering damper http://www.roverparts.com/Parts/9387.cfm
when i see pictures of this it looks like it is in front of the steering rods but my factory steering damper is behind the steering rods...
ryan mura
1994 range rover county lwb
-BIG BLUE 3" coil spring suspension lift
-Procomp ES3000 shocks
-custom snorkel
-glasspack exhaust system
-285/75/R16 all terrain tires
-old school CB radio from the 80s-cobra
-speakers loud enough to set off car alarms
-LR3 side air vent
ryanc8514 is offline   Reply With Quote
Old 04-18-2006, 08:37 AM   #22 (permalink)
Rocky Mountain High
Funrover's Avatar
Here is what I did.... parts from ROCKWARE. www.rockware.net
I love it... I had to relocate my damp. because of the style tie rod i got!!! There is a bend in it for more clearence and it is a lot thicker to take abuse...I bent up the old one bad as well has the dampener
steering-dampener-replacement-img_6094.jpg  steering-dampener-replacement-part2.jpg
Old 04-18-2006, 12:58 PM   #23 (permalink)
ryans ROVER
ryanc8514's Avatar
would i have to relocate mine if i replaced it?
ryan mura
-custom snorkel
-LR3 side air vent
Old 04-18-2006, 01:02 PM   #24 (permalink)
ryans ROVER
ryanc8514's Avatar
nevermind i jus found out i dont have to relocate if i get the OME but it is recommended because the factory steering damper is in a bad position
ryan mura
-custom snorkel
-LR3 side air vent
Old 04-18-2006, 02:15 PM   #25 (permalink)
Otherwise known as STEVE
Woodhead- OEM $49.95
Boge- OEM $49.95
OME- $64.95
ProComp- $55.00
Bilstein- $79.95
Out of all of them, the Boge or ProComp have had the best reports...
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 04-20-2006, 12:03 PM   #26 (permalink)
ryans ROVER
ryanc8514's Avatar
is the steering damper any better or worse when using the relocation kit?
ryan mura
-custom snorkel
-LR3 side air vent
Old 04-20-2006, 12:10 PM   #27 (permalink)
Rocky Mountain High
Funrover's Avatar
The reason I did it was for clearence...... The ride is about the same....The down side to the relocate kit is that is uses a D-90 stabilizer...More $$$ But i think it was well worth it!!
Old 04-20-2006, 12:58 PM   #28 (permalink)
sven's Avatar
Sorry 'bout the hijack...Im selling this: http://landroversonly.com/forums/showthread.php?t=9053
Old 04-26-2006, 11:53 AM   #29 (permalink)
ryans ROVER
ryanc8514's Avatar
im wondering how much of a difference a steering damper makes? i still have my factor one and my tires are a little bigger than stock
ryan mura
-custom snorkel
-LR3 side air vent
