Old 09-28-2006, 01:05 PM   #1 (permalink)
Default steering vibration
I am getting vibration on my 95 classic as early as 35 miles an hour can someone please tell me what is going on with this.?
tebelleh is offline   Reply With Quote
Old 09-28-2006, 03:52 PM   #2 (permalink)
Are the tires balanced? How are the bushings, especially the panhard rod? How are the tie rod ends? How is the swivel preload? There are any number of things that could cause vibration. When and how does it occur. What tends to cause the vibration. Can you provide a little more detail???
Old 09-28-2006, 04:56 PM   #3 (permalink)
gordo's Avatar
at 35 I would quickly check the front u joints as well. is it more of a hum? gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
Old 10-01-2006, 05:07 PM   #4 (permalink)
I have dealt with the steering vibration issues too. I would get a vibration when hitting a bump in the road, usually while going 60-70mph. I have replaced the steering damper, bushings, tie rod ends, and shocks. My steering is good now(knock on wood). Consider replacing these items. From what I have read, the steering vibration is common. Search this fourm, there are some other threads with good info.
j.
1995 RRC
Mayor is offline   Reply With Quote
Old 10-01-2006, 08:00 PM   #5 (permalink)
Rocky Mountain High
Funrover's Avatar
Panhard rod bushing...... they cause vibs... low speed up to 80 (for me)
radius bushings (40 - 65 mph for me)
Tire balance..... just plain off.... but not till above 50... just what I have had happen!
