Old 01-21-2007, 03:13 PM   #1 (permalink)
Sign Guy's Avatar
Default Strange noise coming to a stop
After driving for about two hours in the rain I noticed an odd noise when slowing for a red light. It is engine speed related rather than drive train. Sounds like it is coming from directly below the shifter but it is really difficult to tell. I took it back out about an hour later and it did it again. It will not do it consistently. It sounds like a combination of a belt slipping and a bearing going bad. Could it just be weather related or am I looking at something more serious? Transmission has been maintained. It was flushed w/i the last 15k miles and the fluid is at the correct level and very clean. Any thoughts?
Thanks,
Bill
93 LWB Westminster 155K miles
Sign Guy is offline   Reply With Quote
Old 01-21-2007, 05:47 PM   #2 (permalink)
Jery's Avatar
Cool
Could be the ABS related? Do you feel a slight vibration under the brake pedal when it takes place? Once in a blue moon, I'll have a weird vibration under the pedal in snow.
Jery
Jery is offline   Reply With Quote
Old 01-22-2007, 09:33 AM   #3 (permalink)
Sign Guy's Avatar
Nope, the ABS is not connected pending replacement of an exciter ring. I don't feel it in the pedal or steering wheel. Just an odd noise from somewhere under the truck that relates to the engine speed while coming to a stop.
Bill
93 LWB Westminster 155+k miles
ArmyRover- "it's actually more of self inflicted torture chamber with doors and tires"- with this, I can relate!
Old 01-22-2007, 07:33 PM   #4 (permalink)
Sign Guy's Avatar
It seems like the noise is coming from the idler pulley for the a/c. Used a swab with gear oil and a bit of wd40. We will see tomorrow if it takes care of it.
Bill
