Links
Old 11-15-2006, 05:25 PM   #1 (permalink)
rqwilliamsjr's Avatar
Default Sunroof leak
I have a 89 RRC and wanted to know if anyone has had their sunroof leak? I drove my truck today and it was raining inside and outside of my truck. It sucked. I just had the headliner replace and they told me the drains were fine and the seals looked fine. Any other suggestions?
rqwilliamsjr is offline   Reply With Quote
Old 11-15-2006, 08:10 PM   #2 (permalink)
RageRover's Avatar
Is it leaking right at the sunroof seams?
I could be the glass' seal that is mounted to the glass is not all that great.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 11-15-2006, 08:16 PM   #3 (permalink)
Super Moderator
Disco's Avatar
Do a test yourself. Open the sunroof and pour some water into the drain and see if it backs up and overflows. If it does, blow down the drain holes with compressed air. This should clear the drains. As you don't have Alpine windows and your seals are okay, I cannot think of where else the water could be coming from. Lets know how it works out.
Old 11-16-2006, 11:57 AM   #4 (permalink)
daway's Avatar
like pat (ragerover) said, check around the seal lines to c if there connected to the sunroof and see if the back of the sunroof is closed down (tilt up side) all the way. my rrc leaks in the back when i get a car wash. i think it is the rubber seal around the sunroof. also open the roof and check around the track to see if something is blocking the drain opening.
1993 RRC, county LWB "bertha"
myroverworld
Old 11-16-2006, 01:06 PM   #5 (permalink)
TerryS's Avatar
It's 17 years old. The seals dry out, crack, and shrink. Time to replace the whole seal. Either that, or duct tape the seam. Shabby chique.
Old 11-16-2006, 01:11 PM   #6 (permalink)
RageRover's Avatar
Mine does leak in parts of the windows when I go to the power washer, a little leak at the tail gate.
yeah sooner or later I will have to replace seals.
1995 RRC LWB
Old 11-16-2006, 02:04 PM   #7 (permalink)
Thor's Avatar
I'm about to try the compressed air thing. Someone told me to blow up the seal for some good reason I've forgotten.
I'd like all new seals too.... but the greenies whine when you club the baby ones (they are the most pliable.
Todd
Carpe Rangius Roverum
Old 11-20-2006, 04:51 AM   #8 (permalink)
Well the motor on the sunroof is dead so instead of spending all that money to get it fixed, I just bought a five dollar bottle of silicon and sealed up the outside. This truck is a hunting truck so no big deal.
Old 11-21-2006, 07:30 AM   #9 (permalink)
gordo's Avatar
yeah you blow up to avoid blowing the drain tube off the sunroof itself. Who cares if the seals are bad, as they really dont seal it up anyway. As long as the drains are clear you shouldnt be leaking inside the cab. I still usually have to blow down in the front tubes since they are hard to reach from the bottom. Gordo.
Gordo
www.floridalandroverclub.com
94 D1 mall crawler
92 stocker RRC
73 hybrid wheeler
Thats not me airborne but I love the photo!
gordo is offline   Reply With Quote
