ryans ROVER
i have a 1994 range rover county lwb...my steering is getting stuck sometimes and i think the swivel ball housing needs to be greased...does anyone know how to apply the grease? i bought the tube off the internet but i dont know how to install it...please email me if you have any idea boosteezee@tmail.com
Otherwise known as STEVE
From your symptoms, you need to do more than shoot the 'one shot' grease in the swivels. But to do that, you take off the top bolt head which is the fill plug and squeeze the stuff in there.
Your steering shaft is probably binding up because the exhaust manifold heat dries out the joint bearings on the shaft causing the binding. Spray the bearing joints with WD40 see if that helps if not you probably need a new shaft.
When you put the grease in turn your wheels to one side or the other. The grease will go in much better.
I replaced my steering arm you can read about it here. Maybe it will help. http://www.okierover.com/steeringshaft.htm |
#6 (permalink) | |
Rocky Mountain High
![]() Join Date: Sep 2005
Have any pics? My started to bind very infrequently... Just curious where exactly you were talking about..I'll look tomorrow..Thanks |
They just don't 'dry out'. They become very brittle.
But as bad as mine was I didn't have any trouble with the steering. It was a bit dodgy with the weaving in the lane but lots of things can cause that. Bushings for one which I know need replacing. |
#10 (permalink) | |
I was able to cure mine by spraying the flex joints with WD-40 then exercising by turning the steering wheel back and forth. I then put a couple drops of 30 weight oil on each bearing. If the bearings are shot you will probaly have to order a new shaft. How do you guys post pic's? |
