Classic 95 SWB NAS
I bought a two bags of swivel housing grease. I haven't put them yet. What is your opinion about grease vs/ oil? How do you change? Just drain the oil and squeeze the grease in?
I have to top off swivel oil quite often, so it may be the right time to switch to grease. But does grease have the same lubricating ability? Any experiences? |
I used grease in my D1, because the swivel balls leaked. When I got my RRC. I found grease in them, but I noticed they were not really full. I ran out of grease so I put oil in one...no leaks....
cool!
Eric The Red 93 Range Rover Classic ![]() We will never "arrive" so the goal is to keep moving forward on our journey so we can periodically declare, "I am not what I want to be, but I am not what I used to be!" 96 DISCO SE7 5-SPEED SOLD ![]() ....okay couldn't live without a disco!96 DISCO SD 5-SPEED -ARB Bumper -OME 2" Lift -2" spacers -Safari snorkel -15" steelies
Grease in mine. No reason why you cannot put a little oil in there too if your worried about dryness though!
1992 K-reg 200TDI Defender 90 (Eva) MSN - Geobloke@hotmail.com There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill |
If you have a problem with leaky swivels then grease does make life easier. However, should you do a lot of off-roading and find yourself knee deep in water on a regular basis, grease looses its appeal. Cleaning your swivels after they've been contaminated with water and other foreign objects is a lot easier when you use oil. All you do is drain and replace. With grease, to really clean your swivels you need to disassemble them. In the end, if you have leaky swivels, fix them right and you won't have any worries. Do a half-assed fix and it will eventually get you.
My preference, oil. It's worked on Land Rovers since 1948. |
If you're truck is going to see water, you should consider using grease AND oil...a 50/50 mix...this lets the filling keep its lubricating properties and allows it to be easily drainable. That way you can change it effortlessly everytime you're going to change it.
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD 2.25L Dsl - Wilks 1965 Series IIa 88' LHD 2.25L Petrol - Fionna |
Classic 95 SWB NAS
Thanks for the opinions guys. It seems that in may case I should go for grease. Can I just drain the oil and squeeze in the grease where I normally put the oil? Or do I need to go inside and "pack" the joints?
#9 (permalink) | |
Rocky Mountain High
![]() Join Date: Sep 2005
Yup...just drain out the old and fill it in with the new!!!! |
#10 (permalink) |
what r the sizes to open up the filler holes and there is a level hole to?
2001 X5 3.0i "dodi" 1993 RRC, county LWB "bertha" 1991 RRC (dad's), parting out (email me or check out the link below) myroverworld |
#11 (permalink) | |
Rocky Mountain High
Been a little since I last did itt so I don't remeber the sizes...But I get the actually LR greese...Has the correct amount in the tube ready to go! |
#12 (permalink) | |
#13 (permalink) | |
Rocky Mountain High
It's never been hard for me to clean....But I have never tried to use just part...I have always used the entire tube! |
#15 (permalink) |
Where is my Black Son?
Ok, so I took a look at my swivel balls(lol) and i realized the plugs are really weird. what do you guys use to remove the plugs. they are all sqaure heads or somehting.
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler. 1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
