Old 12-14-2006, 06:43 AM   #16 (permalink)
Sign Guy's Avatar
I added 90wt to the passenger side and realized that it was pouring out of the bottom of the seal and running down the tire. Upon further inspection I realized that a previous owner had hit a rock or something which slightly scarred the swivel and pulled the retaining ring for the seal back far enough that I could see the spring that is supossed to be inside the seal itself. At that point I figured adding wheel bearing grease was better than having nothing in there, right? Today I am going to take a peice of wood and a mallet and see if I can't coax the retainer back in so its not acting like a hood scoop directing crap into the swivel housing. Anybody change one of these out??
Thanks,
Bill
Sign Guy is offline   Reply With Quote
Old 12-14-2006, 08:13 AM   #17 (permalink)
KevinNY's Avatar
I think a lot of folks in the thread are confusing BEARING grease with SWIVEL BALL grease. Bearing grease is the heavy sticky stuff you pack wheel bearings with. Swivel ball grease is a semi liquid moly grease that flows, albeit slowly. It comes in premeasured tubes, 375 ml per swivel ball.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 12-14-2006, 02:47 PM   #18 (permalink)
Super Moderator
Disco's Avatar
I've only ever used the oil and see no reason to change.
Old 12-14-2006, 06:21 PM   #19 (permalink)
Ian Matthews
p76rangie's Avatar
If oil leaks out, water will leak in. So fix your seals are use oil. Grease allows air pockets that restrict lubrication, and traps moisture that causes rust.
Old 12-15-2006, 09:43 AM   #20 (permalink)
Where is my Black Son?
Originally Posted by MuddyRangeRover
Ok, so I took a look at my swivel balls(lol) and i realized the plugs are really weird. what do you guys use to remove the plugs. they are all sqaure heads or somehting.
anyone?
1996 Disco 1 SE7- Stock(Awesome sound system) DD/Range Rover hauler.
1990 RRC SWB Camel Trophy Inspired- ARB, Hella's, Bosch's, AR's 15X8, 32"MTR's,Equipe suspension stuff, Skids, waiting for more...
MuddyRangeRover is offline   Reply With Quote
Old 12-15-2006, 10:48 AM   #21 (permalink)
Sign Guy's Avatar
As forgetting the bolts out just use a small adjustable wrench or open ended wrenches. The drain bolt is actually a head head but I didn't seem to have the right size for it so...once again...an adjustable. I couldn't get the filler bolt out at all and just added direclty through the level access.
Old 12-15-2006, 01:07 PM   #22 (permalink)
Ian Matthews
p76rangie's Avatar
I use an extension bar for the small socket spanners. THe drive on the socket is the same size square head on the bolt. Then I use a spanner on the other end of the extension bar to undo it.
Old 12-16-2006, 11:41 AM   #23 (permalink)
WWTSD? (what would Tony Soprano do?)
stevo-II's Avatar
I think they are 1/4 square bolts - mine were stuck pretty good, so I took a socket adaptor - 1/4 to 3/8 drive adaptor (1/4 female - 3/8 male) and put it on the bolt, then put a 3/8 wrench on the other end of the adaptor and they came out just fine. I tried to put a 1/4 wrench or adjustable wrench on the bolt and it ended up sliding off and rounding the head.
Steve
2001 D2 -The Stevo-II
1992 RRC-The Stevo-I
stevo-II is offline   Reply With Quote
Old 12-16-2006, 12:30 PM   #24 (permalink)
Greg M's Avatar
Ditto on the adjustable wrench. I use a multi weight 90/140 oil. It seems to help a little on the leakage.
Greg M
1987 RRC
Rovers haven't made it to the far reaches of the Earth worrying about warning lights.
Greg M is offline   Reply With Quote
Old 12-26-2006, 10:24 AM   #25 (permalink)
Series Moderator
onslow's Avatar
Default big hammer
anyone?
If they refuse to budge hit the top a few times with a hammer and retry usually does the trick if not a little heat off a blowtorch does it too but dont get em too hot
Old 12-27-2006, 08:15 AM   #26 (permalink)
Ok, so did them on monday. Not TOO hard, but they took a little force to come off. THe Fill plug on the Driverside didn't wan't to budge so I had to fill through the level check. The pass. Side ball had almost nothing in it, the drivers had some disgustingly dirty grey worm like liquid come out of it. I will run it like that for a bit, and change it again, just to try to get rid of as much of the crap as I can.
Old 12-27-2006, 10:53 AM   #27 (permalink)
daway's Avatar
i had the samething happen w/ the bolts (PIA)! i found on BA that they sell bottles of grease now. i wonder if it would make it easier to get it out? http://www.roverparts.com/Parts/STC3435.cfm Also i found that if u set it in the sun or set it in warm H20 first, the grease will come out faster.
i changed my grease acouple of month ago and i noticed that the grease is pushing out (small amount) around the swivel housing ball on the drivers side. above the plate w/ bolts were the level and drain plug are. i noticed when i changed that side, very little grease came out and there was dried caked on grease around the swivel housing ball and the bolts/plate below the swivel housing (not alot)? maybe my seals need to be replaced or the old grease was dried up and i did not get it all out and it made the new grease start to push out? i remember paul grant on rangerover.net forum stated that u sometimes have to unbolt around the swivel housing and clean out the old dried grease. i will take a pic tonight or tomorrow. any1 have any ideas? my rover drives straight as an arrow and no shaking and etc.
2001 X5 3.0i "dodi"
1993 RRC, county LWB "bertha"
myroverworld
Old 12-27-2006, 12:07 PM   #28 (permalink)
I am running gear oil, as per suggested, and plan on changing it very often, especially when i start wheeling again, as I do a lot of Mud and water. I will also be changing my Diff oil fairly often too.
I don;t know what is more benefitial, oil or grease. I reckon, as long as something is in there, its fine.
