Old 09-25-2007, 04:30 PM   #1 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Default Swivel seals
I've been informed that the right front swivel housing is losing oil at an alarming rate when my dad took the Rover in for a tire rotation before the drive to new hampshire.
I found lots of articles about the oil or grease debate and have one question is the grease something you pick up at the dealership or is it available at your local auto parts store?
Has anyone done a how to on replacing the seals on the swivel housing if not has anyone done it that can offer some guidance?
thanks for the help guys and gals
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 09-26-2007, 01:14 AM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
Replacing seals is not difficult. Undo the 2 bolts holding the brake caliper to the swivel and move it out of the way. Remove the tie rod end (and steering rod if doing the passenger side). Undo the the small bolts holding on the metal ring that holds the seal in place. Undo the 4 or 5 bolts that hold the swivel to the diff housing and slide the swivel housing (complete with axle attached) out of the diff housing. Remove old seal and slide it off over the end of the axle, slip in the new one and put it back together.
Old 09-26-2007, 06:08 AM   #3 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Doesn't sound to horrible but aren't those usually famous last words lol
http://snhlr.org/
90 RRC Parts truck
Old 09-26-2007, 06:51 AM   #4 (permalink)
KevinNY's Avatar
Just be ready for the weight of the hub/axle assembly. Leaky swivels are often a result of insufficient swivel bearing preload too, so even new seals will see it leak. The grease is NOT regular auto grease but a moly semi liquid grease available from AB or any of the LR parts houses. 375mm containers, 1 per side.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 09-26-2007, 08:07 AM   #5 (permalink)
OkieRover's Avatar
Gallery: 2
Has anyone done a how to?
Why yes.
Check out my website.
I punch my clown daily.
Old 09-26-2007, 05:15 PM   #6 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Okie is it in the thread with the cv replacement?
http://snhlr.org/
90 RRC Parts truck
Old 09-27-2007, 06:48 AM   #7 (permalink)
OkieRover's Avatar
Gallery: 2
Yeah. There are only 6 more bolts and you are to the seal.
Old 09-27-2007, 10:16 AM   #8 (permalink)
Rebuilding Rover
ArmyRover's Avatar
looks like luck may be with me maybe it seems after power washing all the grime off that the leak is coming from the flat plate that seals to the hub housing and not the swivel seal.
Still haven't decided if that is an improvement or not o well I will figure it out when she arrives on the 5th.
http://snhlr.org/
90 RRC Parts truck
Old 09-27-2007, 12:55 PM   #9 (permalink)
OkieRover's Avatar
Gallery: 2
Dammit man, Pictures!
In any event it's "easy" to get to once you've torn it down.
Have you considered replacing any of the other bits while you've got it apart?
Stock up on all the lubes, when you're done there won't be any lube left in there.
Old 09-27-2007, 02:36 PM   #10 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I'll take pics of the problem area once it gets here. As far as pics of the truck I already posted a few up.
but here is one
http://snhlr.org/
90 RRC Parts truck
Old 09-27-2007, 04:40 PM   #11 (permalink)
OkieRover's Avatar
Gallery: 2
It's the problem area I want to see!!!!
But hey....that truck looks like it's beggin' for modification.
Old 09-27-2007, 04:59 PM   #12 (permalink)
Rebuilding Rover
ArmyRover's Avatar
It's getting a 3" lift when it gets here a new hood and upper gate and a change from tan interior to gray.
http://snhlr.org/
90 RRC Parts truck
